Author Topic: Help - Armor Attack with background is now too small  (Read 1582 times)
quarterback
« on: December 04, 2004, 05:00:10 pm »
I finally downloaded the background files for Armor Attack, but now that it's using the artwork, the part of the screen that's used for playing the game is only about 25% of my screen size instead of full sized.
I took a look at the files in the artwork and it looks like there's a B/W file that tells mame where the bezel should be and the .art file that has other info for the layout.  I tried changing the bezel  setting to "0" inside the .art file, and the bezel disappeared but the play area is still too small.
Do I need to change the "bezelmask" file as well?
-- Chad Tower
biscoradio
  • Last login:April 05, 2006, 08:48:43 pm
  • solder wire to your brain
    • biscoRADIO
Re: Help - Armor Attack with background is now too small
« Reply #1 on: December 04, 2004, 05:27:21 pm »
I usually just rename the artwork file to whatever-backup.zip... Then the game doesn't use it at all and I don't need to mess with the game's individual settings.
quarterback
« Reply #2 on: December 04, 2004, 06:16:37 pm »
Yeah, Armor Attack is the only one I'm using because it provides a background that shows you where things are that you need to see because you have to drive around buildings.  Without the background, you can't see them and you just run into invisible objects.
-- Chad Tower
quarterback
« Reply #3 on: December 04, 2004, 06:58:59 pm »
Solution found:
After trying various numerical parameters in the .art file and after creating new alpha channel mask-files, I discovered the solution was simply to delete the armorabezelmask.png file and delete the bezel information out of the .art file
Now I can play it full screen with the background as well.  Yeah! :)
-- Chad Tower
