Author Topic: starting up with AVGA  (Read 4977 times)
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
« on: December 02, 2004, 11:41:33 pm »
So I'm looking into building my own PC now and I'm considering an ASUS mobo that has no onboard video. I've got my AVGA and a D9200 monitor. What I want to know is, how will I be able to put the system together without another video option? Will the AVGA work the first time I plug it in? I won't have any other monitor option for installing drivers or changing settings. Will this work?
Heck for that matter it won't even have an OS on it when I get it. This is totally from scratch. Can this be done?
« Last Edit: December 02, 2004, 11:56:36 pm by JCKnife »
Re: starting up with AVGA
« Reply #1 on: December 03, 2004, 09:44:51 am »
Guess you need to try it and find out!
(I actually don't know the answer yet)
JCKnife
« Reply #2 on: December 03, 2004, 10:23:20 am »
I found a $17 PCI video card I can use for system set-up. Maybe that's the best answer.
« Reply #3 on: December 03, 2004, 10:24:18 am »
In either case, could someone answer his question?  I'd like to know, I'm about to do this myself.
Troz
  • Last login:October 08, 2010, 11:30:30 am
    • Twisted Rails
« Reply #4 on: December 03, 2004, 11:08:40 am »
I installed a fresh copy of XP using ArcadeVGA and my arcade monitor.  The only problem I had was that I could only see the top half of the screen during the first section of Windows installation.  As long as you know the keypresses needed you'll be ok.  After the first reboot during installation I was able to see the full screen.
Also, I wasn't able to get the ArcadeVGA drivers installed on a XP installation that had SP2 slipstreamed into it.  I had to reinstall a version of XP without SP2 integrated to get it to work.
« Reply #5 on: December 03, 2004, 11:17:04 am »
Right... so the best approach is to use a regular video card up until the first reboot, then switch.  Got it.
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
« Reply #6 on: December 04, 2004, 12:06:18 pm »
using a normal vieo card can lead to driver/regisrty problems later with the arcade VGA.
find a step by step walkthru for installing windows xp fresh and print it out, then do it blind, with only half the screen showing using the acracdeVGA ..
thats how i did it...
Enjoying the fruits of technological obsolescence one game at a time...
« Reply #7 on: December 04, 2004, 04:19:18 pm »
There are no drivers installed at the first reboot point during the install.  It's using the same generic default video driver for pretty much every card at that point.
krick
  • Gotta have blue hair.
« Reply #8 on: December 05, 2004, 01:59:20 am »
I installed my ArcadeVGA the way described on the Ultimarc site.
I installed windows with a regular video card connected to a PC monitor.
Went into hardware manager and "uninstalled" my old card.
Shut down, removed the old card.
Plugged in the ArcadeVGA, connected to the arcade monitor.
Booted up and installed ArcadeVGA drivers.
Note that my normal video card was a Nvidia based card.
Using an ATI card *might* be the cause of DYNAGOD's problems
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
StephenH
« Reply #9 on: December 05, 2004, 03:33:30 am »
You may want to boot in safe mode and install the ArcadeVGA drivers, if windows tries to install the stock ATI Driver (which will not work with AVGA)
