Author Topic: hantarex picture tube  (Read 1515 times)
manefreak
  • Newbie
  • Last login:December 18, 2004, 06:12:31 pm
« on: December 02, 2004, 10:55:50 am »
hi Ive got a Hantarex MTc900/e monitor. i had this given to me for a spare but i did notice on the yoke there is a broken resister and i cant read its value. can anybody help?
jclaeys
  • Last login:June 27, 2005, 04:44:29 am
Re: hantarex picture tube
« Reply #1 on: December 12, 2004, 02:08:24 am »
Hi,
I have a Hantarex MTC 900 . If you upload a picture, I could let you know what's on there.
Best regards,
Joachim
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
« Reply #2 on: December 12, 2004, 09:51:32 pm »
There are no resistors on the yoke.  Are you referring to the neckboard ?
There should be a number silkscreened on the board where the resistor mounts, like R143 for example.  That will identify the resistor in question.
Usually if you have a resistor problem on the neckboard on a 900 it will be either r141, r146 or r143, resulting in a loss of one of the colors.
Those 3 resistors should be  3.3k ohms at 1/2 watt.    For some reason I see 1/4 watt resistors there from time to time, they need to be at least 1/2 watt or they won't last.
D
