Author Topic: will ram do the trick?  (Read 2330 times)
datac0re
  • Last login:April 24, 2005, 05:22:11 pm
    • Mametastic
« on: November 28, 2004, 03:26:17 pm »
Hey guys,
I have my cabinet up and running with an older computer, but games like Time Killers, MK, Altered Beast, Neo-Geo games, and side scrolling shooters are practically unplayable because they're so jerky. Here's the PC's specs:
PII @ 400 Mhz
128 Megs SDRAM
64 Meg GeForce 2 Pro
20 GB Hard drive
Windows XP
Besides tweaking some of the MAME settings in the .ini file (which I've already done), would adding more ram (like another 128 Megs) solve the problem?
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
Re: will ram do the trick?
« Reply #1 on: November 28, 2004, 03:44:31 pm »
First thing I'd do is drop Windows XP and run 98 on it.  XP is going to run pretty crappy on a PII 400 regardless of how much RAM you put in it.
That said, 128mb is insufficient for any system, regardless of CPU, running XP.  256mb is the minimum you want to have, 512 is better.
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #2 on: November 28, 2004, 03:54:05 pm »
For the record, Win98 has memory (addressing?) issues above 512, so for a 98 box, you shouldn't go through any undue efforts to increase it above 512
Make sure you're running the MAME version optimized for your system, that'll help as well
Look for anything running in the background that may be stealing cycles from you
datac0re
    • Mametastic
« Reply #3 on: November 28, 2004, 03:56:41 pm »
Actually XP itself is snappy as hell on the PC by itself. MAME is the only thing suffering. I've already disabled all the non-critical services as well. Since XP runs so well, that's why I wanted to know if my MAME problems were just RAM related.
mnm1200
  • Last login:March 10, 2006, 05:55:34 pm
  • IANAL: I am not a llama!
« Reply #4 on: November 28, 2004, 04:01:43 pm »
There's a whole lot of services in XP running in the background. Have you already disabled most of them that you dont use?
You could also try http://nuhi.msfn.org/ first before getting more RAM. It helps optimize XP.
With this, you should get a good boost of available RAM and may not have to purchase more
Demon Dog? Urusai! ...Baka
datac0re
    • Mametastic
« Reply #5 on: November 28, 2004, 04:10:52 pm »
I'd be leary of using something like this, as who knows what kind of hacks it's going through to do what it says. Also, I can't see how it'd be any better than just disabling the appropriate services.
subzero23
  • Last login:April 24, 2017, 03:21:43 am
« Reply #6 on: November 28, 2004, 04:22:26 pm »
No one really answered his question but no, ram will not help
it's all about processor speed
upgrade the processor
my computer with 866mhz and 512mb of ram can't run those games either
This user has been banned by saint and cannot reply. --- saint
mnm1200
« Reply #7 on: November 28, 2004, 04:43:18 pm »
It just does what you could do if you had the time and skill... It not only does services but other deeply embedded Windows functions. I use a pay version of this and it really helps cut down on proc usage, RAM usage, and HDD space
