Author Topic: monitor picture is bent....  (Read 3423 times)
mamerocks87
  • Last login:March 17, 2007, 12:21:33 pm
« on: November 27, 2004, 09:09:42 pm »
The top corners of my arcade monitor picture is kind of bent in the top corners. I can deal with it but i would like to fix it.
Witchboard
Re: monitor picture is bent....
« Reply #1 on: November 27, 2004, 09:12:53 pm »
Does it stay in the same place or roll up/down the screen?
mamerocks87
« Reply #2 on: November 27, 2004, 10:23:57 pm »
It stays in the same place.
-Kyle
SirPeale
  • Green Mountain Man
« Reply #3 on: November 27, 2004, 10:43:21 pm »
Capkit?  How old is it?
mamerocks87
« Reply #4 on: November 27, 2004, 11:15:18 pm »
Has a new cap kit....
SirPeale
« Reply #5 on: November 28, 2004, 04:09:28 pm »
Degaussing is what you do when the colors are rainbow-y.  You've got - I think - pincushion.  Not sure what to do about that.  Ken?
Ken Layton
  • Guru
  • Technician
« Reply #6 on: November 28, 2004, 11:57:13 pm »
Make and model of monitor please.
mamerocks87
« Reply #7 on: November 29, 2004, 04:34:02 pm »
It is a Wells Gardner 27" Standard resolution monitor.
MODEL # WG2774
-Kyle
mamerocks87
« Reply #8 on: November 29, 2004, 09:13:42 pm »
UPDATE:
I emailed the person I bought it from and he agreed it looked like it was pincushion. There is no pincushion adjustment on the controller, so is there a manual way to correct this?
-Kyle
Ken Layton
  • Guru
  • Technician
« Reply #9 on: November 29, 2004, 10:15:17 pm »
The pincushion coil could be bad. It is not adjustable. Does this monitor have a plug-in "pincushion correction board"?
mamerocks87
« Reply #10 on: November 30, 2004, 04:40:33 pm »
Im not sure. How can i tell if it does? What do i look for?
-Kyle
mamerocks87
« Reply #11 on: December 01, 2004, 12:17:41 pm »
Could the problem be with the resolution or refresh rates?  The screen has blurry corners.  I really would like to fix this because i doubt my guns will work with this because the picture does not fill up the entire screen. It will probably be miss calibrated.  Also what does a plugin pincushion correction thingy look like? Please help,
-Kyle
Ken Layton
  • Guru
  • Technician
« Reply #12 on: December 03, 2004, 12:23:52 am »
Oh, you have a Wells 7400 monitor. I don't usually see those monitors in machines I work on.
All the pincushion stuff is built into the main monitor board. Pincushion coil or pincushion correction circuitry may have problems.
