Author Topic: Precaution: Could this screw up my laptop in anyway?  (Read 1507 times)
subzero23
  • Last login:April 24, 2017, 03:21:43 am
« on: November 25, 2004, 04:22:00 am »
Just a precaution but I want to make sure I'm safe here,
I'm an experienced solderer, and was thinking of making a playstation controller hack and wiring it to the buttons/joystick and then using a PS-to-USB converter from radio shack. Theoretically if my circuits/soldering is dead-on and everything is connected as it should, should I have any problems or anything to worry about? I've never had a bad experience but I've never had $1000 laptop to worry about either.
This user has been banned by saint and cannot reply. --- saint
paigeoliver
  • Awesome face!
Re: Precaution: Could this screw up my laptop in anyway?
« Reply #1 on: November 25, 2004, 04:24:57 am »
If you accidently get +5 and ground shorted out, then you will be in trouble.
Try it in a playstation first, those are much cheaper, if it works there then you are fine.
subzero23
« Reply #2 on: November 25, 2004, 04:48:45 am »
Yeah assuming it works, which it probably will since I've tried on PS2 before and WILL test it on one, I should have nothing to worry about?
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #3 on: November 25, 2004, 06:35:40 am »
Well, it is a hack... and anything can happen.
I guess you'll need to ask yourself... do I feel lucky?
Well... do ya?  :police:
paigeoliver
  • Awesome face!
« Reply #4 on: November 25, 2004, 07:24:08 am »
I once made the mistake of trying to "test" my 49-way with SJC setup on my laptop after I have the joystick wired, but just had the button wires coming off the harness. It worked, I left it hooked up as I hooked up the buttons one by one.
To make a long story short I burned the sucker up, as some voltage got grounded out by a loose wire.
