Author Topic: Sega Genesis Controller on a pc (gameport)?  (Read 5844 times)
RoboG2
  • P&R
  • Last login:August 15, 2008, 10:21:26 pm
« on: November 24, 2004, 10:14:33 pm »
Is there any whay to use a sega genesis contoller on a pc?  It fits perfectly in the gameport (same plug), but it wont work for anything.  I tried using a similar driver from sega for their pc version of the same controller but that didnt work.  Thanks in advance.
TheGatesofBill
  • Last login:August 22, 2018, 09:07:04 am
Re: Sega Genesis Controller on a pc (gameport)?
« Reply #1 on: November 24, 2004, 10:17:53 pm »
The Genesis controller fits into the serial port, and it will not work there as it uses parallel communications.
RoboG2
  • P&R
« Reply #2 on: November 24, 2004, 10:20:32 pm »
Is there any way to hack it so that it can?
TheGatesofBill
« Reply #3 on: November 24, 2004, 11:04:10 pm »
No, but there is a way to hack it so it connects to the parallel (printer) port. It shouldn't be too hard to get it wired up to the gameport either.
JMDickson
  • Last login:October 21, 2011, 11:22:48 pm
« Reply #4 on: November 24, 2004, 11:21:32 pm »
Sega Genesis controlers use the same pinout as Atari joysticks (they were sued for this as Atari had a patent on the layout).  The B, C, and start buttons are just attached to unused pins.  If you use any of the Atari joystick - pc gameport plans, it will get the d-pad and A button working.  Then you should be able to attach the other pins to get the rest of the buttons working.
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
« Reply #5 on: November 25, 2004, 03:27:36 am »
gen controller pinout;
http://www.gamesx.com/controldata/gencont.htm
Driver that should work, maybe...
http://ppjoy.bossstation.dnsalias.org/
Thos links are probly somewhere else on this site already. I actually was thinking about making one usb controller adapter that could do most of the console controllers... eventually I will get to that project.
-FTen
