Author Topic: MegaloMAME  (Read 5033 times)
MegaloMAME
« on: November 24, 2004, 09:19:09 pm »
Okay, I've been meaning to get to this for almost a year... this is going to be my first MAME cabinet and yes I'm starting big.
Re: MegaloMAME
« Reply #1 on: November 24, 2004, 09:20:26 pm »
Okay, first up:  Let's get decent video on that monitor from a PC.  Unfortunately, I have to wait until those monitor cables arrive, which will probably be until after the Thanksgiving break.   :-\
SirPeale
  • Green Mountain Man
Re: MegaloMAME
« Reply #2 on: November 24, 2004, 09:23:00 pm »
Isn't this cabinet JAMMA?  Why didn't you get a J-PAC instead?  A lot less wiring, and probably less complicated getting your monitor working.
Re: MegaloMAME
« Reply #3 on: November 24, 2004, 09:45:11 pm »
Until we'd spoken offline, I didn't realize the Jpac actually will support more than the JAMMA standard 3 buttons...  I'll have to give that one some thought.
SirPeale
Re: MegaloMAME
« Reply #4 on: November 24, 2004, 10:04:36 pm »
After doing some research to the Model 2 hardware, you'll need to either completely rewire (which wouldn't be so bad, but you couldn't use the VF2 board anyore) or get a Model 2 --> JAMMA Adaptor.  In one of your threads someone showed you a picture of one.
I did a brief Google search, and came up with nada, however.  But someone, somewhere, must know something about it.  Just not me.
Re: MegaloMAME
« Reply #5 on: November 24, 2004, 11:56:32 pm »
I'd rather rewire, since I'm making a new control panel anyway.  I can just put the old wiring/panel back later if I want to revert the cab.
Mr-Megalo
  • Last login:July 13, 2006, 08:36:28 am
  • Piano fingered Capcom Addict
Re: MegaloMAME
« Reply #6 on: November 26, 2004, 12:19:07 pm »
your megalo cabinet is very different to the one I have, as for the Model 2 to JAMMA adaptor, have you looked at coinopexpress or cosmicco ?
Re: MegaloMAME
« Reply #7 on: November 26, 2004, 05:43:13 pm »
Nope, don't need an adapter.  I'm going to rewire.
Re: MegaloMAME
« Reply #8 on: November 27, 2004, 07:31:05 pm »
Okay, this is really pissing me off.  I've been trying to get this ArcadeVGA installed.  I don't have the monitor cables yet so I'm trying to do it via the composite output.  I switched the Diamond video card with the ArcadeVGA and got no video signal and couldn't tell if it even booted, I suspect it did not because I didn't see much disk activity.  I put the Diamd on tond back in and it booted fine so I followed Dynagod's advice and removed the Diamond drivers before switching again.  Same result with the ArcadeVGA.
Could it be that you cannot use the composite until the ArcadeVGA drivers are installed?  I don't have anything needing to be saved on that drive so I could easily just blow it away and reinstall windows.  Would that be the next step, or am I stuck until I have the monitor cables?
vader
  • Last login:December 27, 2025, 08:14:42 pm
  • I can't breathe in this thing !!
Re: MegaloMAME
« Reply #9 on: November 28, 2004, 12:06:09 am »
Chad, I believe you are right  and it won't boot composite till drivers are loaded.
Load Drivers
Switch to Composite as primary display
reboot......
Tim
Re: MegaloMAME
« Reply #10 on: November 28, 2004, 10:57:13 am »
Thanks for the info... I can't get the drivers loaded, obviously, until I have the rgb cables in hand.   :-\
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
Re: MegaloMAME
« Reply #11 on: November 30, 2004, 06:08:53 pm »
couldnt hurt to throw a line at andy at ultimarc. im sure he gets bombarded everyday by questions,but im sure he'd get back to you with any wisdom he can offer.
Enjoying the fruits of technological obsolescence one game at a time...
Re: MegaloMAME
« Reply #12 on: December 01, 2004, 09:23:38 am »
It's no major rush... I'm just waiting on the RGB cables I ordered.  If I were in that much of a hurry I have a spare 5 BNC VGA cable I could use.  All i'd have to do is connect the two sync lines to get a combined sync, yes?
