Author Topic: a little sag on the right!  (Read 1296 times)
Granger
  • Last login:June 29, 2006, 02:46:26 am
« on: November 24, 2004, 12:56:56 am »
building an ultimatearcade II cab, was coming along very well... bolted right side down, stood upright, leveled and clamped left side, but slid 1/2 inch while drilling. ouch!!!! What do  I do?
« Last Edit: November 24, 2004, 12:58:28 am by Granger »
186,000 miles per second, not just a good idea, it's the law.
krick
  • Gotta have blue hair.
Re: a little sag on the right!
« Reply #1 on: November 24, 2004, 01:15:17 am »
Not really sure what advice to give you other than the generic answer that everyone will probably give you...
Drill it again in the correct spot and fill in the extra hole with some wood filler.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Granger
« Reply #2 on: November 24, 2004, 01:27:31 am »
1/2 inch bolts, 1/2 inch off,  basically i will have to make a slot. worried it will not stay and slowly drift down over time.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #3 on: November 24, 2004, 01:56:46 am »
Get a 1/2" dowell and use it to plug the wrong hole, then drill your new one.
Granger
« Reply #4 on: November 24, 2004, 02:08:26 am »
should have thought of that. was too upset to think of the obvious answer. thanks!
