Author Topic: Ultimarc Joysticks  (Read 2197 times)
bishamon
  • Last login:September 30, 2002, 07:56:13 am
  • root down
Ultimarc Joysticks
« on: September 25, 2002, 03:50:33 pm »
I am thinking of picking up some ultimarc j-sticks for my new panel - Has anyone used these in a project? Am I better off getting some Happ Supers?
hyiu
    • www
Re:Ultimarc Joysticks
« Reply #1 on: September 25, 2002, 04:08:43 pm »
depends on what you like... the J-sticks are very good sticks....
I have a ball top J-stick on 1 of my joystick now...
a couple of things that I noticed....
there are 4 screws that you need to screw tight to lock the template... you'll need to screw them tight... when I play SF, after about 20 min of playing.... if the screws are loose... the template will rotate by itself... (maybe cos I play too hard... heee hee...)
another thing about it that I didn't like too much is that the 4 main direction has a shorter distance than the diagonals....
the template is like a square... so... go up travels faster.... going diagonal is longer....
its not a big deal.... but needs to get used to....
cos I was playing 8 way games and when I go up... I sometimes ended in a diagonal....
out of all the joysticks.... I still like competition with heavy spring the best..... (just me personal preference...)
but Super, Competition, and the J_stick are ALL VERY GOOD sticks....
hope it helps...
;)    ;D   ;)   ;D
ps: but the construction, design wise... I think J-stick is the best... its smaller and nice....
bhille
  • Last login:January 02, 2003, 11:39:40 pm
  • Be the ball...err...be the arcade machine...
« Reply #2 on: September 25, 2002, 05:23:23 pm »
Has anyone tried a T-stick?  Does a T-stick have the same basic issues that the J-stick has?
Brian
