Author Topic: Mouse Hack Issues  (Read 1546 times)
crashball
  • Last login:November 20, 2004, 09:02:30 pm
Mouse Hack Issues
« on: November 20, 2004, 06:25:55 pm »
I picked me up a suzo trackball from Ultimarc and am attempting the mouse hack interface like on Lusid's web site.  My problem is I can't get it to work after soldering the connections to the mouse PCB.  I tried to test it before removing the light reader diode thing (not the technical name i know) just by holdin the wires to the soldered contacts and was able to get some movement.  After removing the sensors and soldering the wires, i get nothing.  I think I am using the right kind of solder but the package is long gone. Is there anyway to tell what kind I have?  If I remove the solder on the connections it looks as if the metal or shiny ring around the hole is not longer there, like it got rubbed off when I tried to get the solder off. I think the etching may even be coming off on one, I probably baked it.  The PC still detects the mouse and the buttons still work, but no movement.  I Think I have toasted 2 mouse PCBs in one way or another and snapped a 3rd in half trying to get it out of the case. Would the wrong kind of solder not conduct a connection or is my conenction bad?  Any tips from those who have done it would be appriciated.
brained
  • Last login:February 11, 2026, 10:56:20 am
  • Raised by Atari
    • Nux
Re: Mouse Hack Issues
« Reply #1 on: November 22, 2004, 11:10:00 am »
Oscar sells a premade mouse hack for a good price. Check his webpage
http://www.oscarcontrols.com
lusid
  • Last login:January 04, 2016, 11:01:53 am
    • LuSiD's Arcade Flashback
« Reply #2 on: November 30, 2004, 12:06:27 pm »
It's a touchy hack.  Some mice just don't work, and I only tried it with Happ's sensor board.
I think you've killed enough rodents.  Time to buy an interface.
C - - - - - o
SirPeale
  • Green Mountain Man
« Reply #3 on: November 30, 2004, 12:08:57 pm »
It's a touchy hack.
Holy crap!  It's Lusid!
Stingray
« Reply #4 on: November 30, 2004, 12:40:07 pm »
Try this one from Minwah's site. Worked for me.
http://mamewah.mameworld.net/mousehack.html
-S
Mickey Juice
  • Last login:August 27, 2010, 08:29:08 am
  • BLAU!
« Reply #5 on: November 30, 2004, 04:09:19 pm »
Minwah's hack works fine, but you need some pull up resistors to get the Ultimarc t'balls working:
http://forum.arcadecontrols.com/index.php/topic,19100.0.html
Stingray
« Reply #6 on: November 30, 2004, 04:11:39 pm »
Ah, I was not aware of that. I used an Imperial TB.
-S
brained
  • Raised by Atari
    • Nux
« Reply #7 on: November 30, 2004, 04:41:44 pm »
