Author Topic: New Jukebox Software: Arcade Music Box v1.09  (Read 7405 times)
Space Fractal
  • Space Fractal
    • Space Fractal
« on: November 16, 2004, 04:39:13 pm »
Here is a little juke box for lowres arcadecabs with mamewah (wich I using, thanks Minwah) or such installed.
I have added some requested features, like the credit mode (There are 2 credit modes).
but it may have few bugs left, but it work flawless..... If any bugs or any requested features, you can write them on this topic.
==== THIS WAS VERSION F ====
Look for the bottom in the thread for the newest versions.
« Last Edit: November 28, 2004, 12:04:56 pm by Space Fractal / Denmark »
Space Fractal
  • Space Fractal
    • Space Fractal
New Jukebox Software: Arcade Music Box v0.9.1h
« Reply #1 on: November 16, 2004, 04:43:27 pm »
Here is the link:
arcademusicbox.playitgame.org
And a screenshot from version h:
« Last Edit: November 27, 2004, 04:32:10 pm by Space Fractal / Denmark »
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re:(Another) New Jukebox Software: Arcade Music Box v0.9.1e
« Reply #2 on: November 16, 2004, 04:49:25 pm »
Looks very promising.  I like the look a lot.  Will have to download and investigate further.
zaphod
    • ArcadeCab.com
« Reply #3 on: November 17, 2004, 10:14:54 am »
Loaded it onto my cab this morning and gave it a quick (five minute) run through.  I used the default 640x480 skin you provided but the image is stretched off the top of the screen, so I lose the top half of 'Arcade Music Box'.  Didn't see a setting that would cause that but will look around more tonight.
It's very easy to install and use.  I like the fact it uses many of the same buttons as Mamewah.  Good job! :)
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #4 on: November 17, 2004, 12:02:27 pm »
You may need to alter the arcade.cfg file to a better res, that suit your arcade monitor (it created when you say yes with the installer).
I cannot set the monitor hertz in Dark Basic, so I think it use the same monitor hertz, set in desktop.
But it worked fine with to my cab and ArcadeVGA (the old 7200 version).
zaphod
    • ArcadeCab.com
« Reply #5 on: November 17, 2004, 12:12:34 pm »
Thanks.  I figured that was the case.  I'll test it out tonight.
zaphod
    • ArcadeCab.com
« Reply #6 on: November 17, 2004, 06:12:51 pm »
Okay, that worked great.
Another question: can I select an entire album to be played all at once?
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #7 on: November 18, 2004, 02:42:06 am »
Not yet. But I add this in the future version. I have thinked about it.
This feature will of course only added in the free mode.
[EDIT] This is now added in version F [/EDIT]
« Last Edit: November 18, 2004, 09:15:45 am by Space Fractal / Denmark »
zaphod
    • ArcadeCab.com
Re:(Another) New Jukebox Software: Arcade Music Box v0.9.1e [now f]
« Reply #8 on: November 19, 2004, 07:53:45 am »
Thanks again.  I've updated my version and it works great.   :)
Space Fractal
  • Space Fractal
    • Space Fractal
Re:(Another) New Jukebox Software: Arcade Music Box v0.9.1e [now g]
« Reply #9 on: November 21, 2004, 10:06:40 am »
A new version is now aviable with some bug fixed and added features:
21.11.2004: Version 0.9.1g Released
- Crash when entering into a empty folder [fixed]
- Extension support is now easier to made (like WMA and FLAC) [changed]
- It is now possibble to disable the screen saver (set 0 to the timer) [added]
- The another blank screensaver is now only activated from the control panel [changed]
- The blank screensaver text color can now been edited by prefs.cfg [added]
- There was some skin bugs in the vertical and the 400x300 version [fixed]
- The auto next queue jumped a song over, if you choosed a song when the queue was emtpy [fixed]
18.11.2004: Version 0.9.1f Released
- The text scroller in the selector could crash on some machines [fixed]
- You can now add the whole folder (album) to the queue (free mode) [added]
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #10 on: November 21, 2004, 05:59:42 pm »
How bout some mouse control for scrolling the lists?
Looks very good besides though :)
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #11 on: November 22, 2004, 09:15:28 am »
There is now a version H with there change (be sad, I forgot to look the trackball control, sorry, but it coming soon):
27.11.2004: Version 0.9.1h Released
- Added a default skin folder, so it doesn't have 3 copiers of same files (for each skin). You can still use own images for your own skin [changed]
- Screensaver vertical was not display correct [fixed]
- The jukebox picture is now used in the normal screen saver (instead of just text) [added]
28.11.2004: Version 1.09 Released
- Mouse & Trackball Support [added]
- When reading a font under the startup, can crash on some machine (like the scroller bug) [maybe fixed]
- Droppede the letter versions. It called version 1.09, because I have made 8 versions in the past [changed]
YES, I have now made that mouse support (as requested)!
« Last Edit: November 28, 2004, 12:03:49 pm by Space Fractal / Denmark »
