Author Topic: Mitsubishi xc3710ss manual needed  (Read 2230 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: November 16, 2004, 03:54:00 pm »
Found a big a** mitsubishi monitor and need manuals, spec sheets, etc.  Google is not helping.  Anyone have any ideas?
Mitsubishi - xc3710ss
Monitorworld had this info:
Model:       XC3310
Max Resolution:       800 x 600
Sync Type:       Composite, Seperate
H Freq/ V Freq:       15-35KHZ / 40-75HZ
Tube Manufacturer:
Monitor Type:       Multisync/Multiscan
Tube Model:
Tube Size:       33
Connector:       3 BNC
I am looking for any other info I can find, thanks!
TacoTownCharlie
  • Last login:October 22, 2025, 05:53:24 pm
  • Old enough to know better
Re:Mitsubishi xc3710ss manual needed
« Reply #1 on: November 16, 2004, 05:10:54 pm »
I have the XC3715; you're right - its a big a** monitor.  I don't think there is much difference between the 3710 and 3715; the 3715 may allow greater resolution or have a different remote, I'm not sure.  I have an .inf file for the 3715, it should have the 3710 in it.  Its at home now, so I'll send it later if you want.  I also have a hard copy of the owner's manual - I found an address for their support group in CA.  I can scan that in for you if you want.  The support group in CA also has a service manual, I think its around $20.  I'll try to find the address info tonight also.
If you are able to support the weight (250 lbs) this is one nice monitor to have.  I've been playing Doom 3 on it lately and my 5 year old has been playing California Speed on the Project64 emu.  Also, it looks great for DVDs.
Like I said, I'll try to find that stuff tonight,
TacoTownCharlie
RetroJames
« Reply #2 on: November 16, 2004, 05:22:05 pm »
TacoTownCharlie
TacoTownCharlie
« Reply #3 on: November 17, 2004, 09:27:53 am »
Here's the inf file. I had to rename it to an allowed file type.  The contact info for the owner's manual is:
Mitsubishi Electric
9351 Jeronimo Road
Irvine, CA 92618
888.307.0308
888.242.3598  Fax
The instruction book is 32 pages, it will take me a while to scan it in and convert to a pdf.  Also, I'll be out of town starting Friday for a week, so it will be after Thanksgiving before I could start.  If you want, I can make a copy here at work and mail it to you.  Send me a pm if that's what you want.
TacoTownCharlie
TacoTownCharlie
« Reply #4 on: November 17, 2004, 09:33:35 am »
Looks like renaming the file did'nt work.  Try a google search for "Mitsubishi inf".  The first result brought up this site http://www.necmitsubishi.com/support/css/signedinf/files2.htm  Just select other mitsubishi models and you'll be able to download the inf file.
TacoTownCharlie
RetroJames
« Reply #5 on: November 17, 2004, 12:39:36 pm »
TacoTownCharlie
Sent pm re: post above, will look for inf online or you can email it to:
james at retroblast dot com
