Author Topic: "Kick" display help needed  (Read 2344 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« on: November 14, 2004, 04:19:13 pm »
My Kick game all of a sudden doesn't display correctly.  It is too big for the screen and is off to the right side....I've tried the .ini settings but I can't get anything to work...
The only thing I changed recently was from Mame .88 to .86 because I didnt like the validity check in .88..
what am I missing here?
I had the same problem with Toobin' but I fixed that in the .ini....I then did a  "save as" figuring this would cure Kick......but it didnt work  ???
Re:"Kick" display help needed
« Reply #1 on: November 14, 2004, 06:59:42 pm »
Why not use MAME v0.88 and just disable validitychecks? ;)
But yes an ini file specifying a suitable resolution should work.  My kick.ini says:
resolution 512x512
Substitute 512x512 for whatever res. you want to run it at...
deadmoney5
« Reply #2 on: November 14, 2004, 08:56:05 pm »
Thanks Wahman...that did the trick...
As to why I switched from .88...
don't you need to turn off validity checks from the source code?
I don't know how to compile...
Are you saying you can turn off validity checks from an .ini?
« Reply #3 on: November 15, 2004, 05:02:24 am »
Yes, mame.ini.  Update it with mame -cc and set skip_validitychecks 1.
