Author Topic: Arcade84 and MinWah  (Read 2777 times)
vader
  • Last login:December 27, 2025, 08:14:42 pm
  • I can't breathe in this thing !!
Arcade84 and MinWah
« on: November 14, 2004, 05:43:24 am »
Since I'm having so much fun with MameWah, I brainstorming now although I know this has come up already.  Is it possible to have MameWah use Arcade84 as a Screensaver when a game isn't being played  and then exit when someone presses a button ?  I doubt it is, but I'm sure hoping...I know you can start up with that, but didn't see anything else....if possible please give me details or link...
Tim
Re:Arcade84 and MinWah
« Reply #1 on: November 14, 2004, 10:07:30 am »
Yep of course  ;D
In your \mamewah\ini\mame.ini file, set movie_path to wherever your arcade84.mpg (& any other movies you might want to play) is (eg c:\movies).  Then set saver_type to movie.
That's it, you will probably want to set enable_music_in_screensaver to 0 too tho :)
vader
« Reply #2 on: November 14, 2004, 12:56:54 pm »
May have just been a glitch, but I tried that earlier I believe and I just received a blank screen, I'll give it another go....
Tim
vader
« Reply #3 on: November 14, 2004, 01:06:54 pm »
I'm getting this error message when trying to set it up from the log
11/14/2004 1:04:41 PM Error 445 Object doesn't support this action in frmScreenSaver:tmrMovie_Timer
Tim
« Reply #4 on: November 14, 2004, 01:18:03 pm »
I presume you are but could you confirm you're using v1.52?
Does it work albeit give you the error message?  Or not work either?
vader
« Reply #5 on: November 14, 2004, 01:53:23 pm »
Yep, definitely using 1.52        It's not working at all and on occasion if I try differnt paths, I will get a internal error from mamewah.  I did at one point last nite have so it would work with a intro movie preview, but no luck in the screen saver section.  I'm gonna email you my ini's so you can see if there is anything there.
Tim
Demon-Seed
    • DemonCade (WORKING URL!)
« Reply #6 on: November 14, 2004, 04:17:59 pm »
Hey
I am a little old but what the heck is Arcade84?
Thx
JIM
vader
« Reply #7 on: November 14, 2004, 05:09:27 pm »
It's  awesome mov or mpg file....you really need to see it.....don't remember the site for download....just google arcade84
Tim
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #8 on: November 15, 2004, 12:26:28 am »
are you using the mov or mpg version? did you try a diferrent mpg just to see if the problem is with the arcade84 itself or the movie?
« Reply #9 on: November 15, 2004, 05:04:25 am »
He got it working with the .mpg file...seemed to be an issue with where it was located (in the \mamewah folder).
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« Reply #10 on: November 15, 2004, 09:29:57 am »
I am having the same issue.  I can get it to run as an intro movie, but I only get a blank screen as a screen saver.  Could someone post the correct .ini for reference?
« Reply #11 on: November 15, 2004, 11:11:42 am »
saver_type movie
movie_path c:\movies (or whatever)
That is all - vader had a problem when his movie was in the MAMEWAH root folder, although it seems to work OK for me.  Check \mamewah\mamewah.log for any error messages...
Scoobie
« Reply #12 on: November 15, 2004, 11:58:00 pm »
That did it!  I had 'movie_path c:\movies\arcade84.mpg' instead of just 'c:\movies'.
NickS
  • Last login:September 11, 2014, 06:59:58 am
« Reply #13 on: November 16, 2004, 08:11:06 am »
Tim
www.cinemarcade.com
