Author Topic: WG 4903 Problem.  (Read 1278 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
WG 4903 Problem.
« on: November 13, 2004, 11:19:46 pm »
Just picked a cab with a 4903 monitor.
The monitor has high voltage, but has a solid yellow (???) pic.
Adjusting the flyback voltage only affects the screen a bit.
(i.e. I can't get it to shutoff completely).
Does this sound like a tube?
(I've got 5 g07 in the house, and not a single other wg, So I can't try the chassis on a different tube.)
Later,
dabone
Ken Layton
  • Guru
  • Technician
Re:WG 4903 Problem.
« Reply #1 on: November 14, 2004, 12:33:21 am »
The 4900 series is well known for many bad solder joints and sometimes a cracked neckboard.  Check that first. Then try a capkit. There could be a shorted color driver transistor on the neckboard. The tube might have a problem, but then again, someone may have 'played' with the color trimpots on the neckboard too.
