Author Topic: Monitor's picture is angled  (Read 1255 times)
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« on: November 13, 2004, 08:18:23 am »
Well this is an odd problem :/ I set up the monitor on the floor to test it and got it all set up and it worked like a charm. Now after I have put the monitor in the cab the picture is at a 15ish degree angle from the top and bottom of the tube...did I shift the neckboard or something?
Ken Layton
  • Guru
  • Technician
Re:Monitor's picture is angled
« Reply #1 on: November 13, 2004, 09:52:04 am »
Check out Bob Roberts' tech pages www.dameon.net/BBBB/ and click on "Slanted Monitor".
DaemonCollector
« Reply #2 on: November 14, 2004, 11:10:26 pm »
Hmm, my picture is perfect but is completly angled, not a distorted angle, but the entired image is...I tried adjusting the Horizontal Hold but that didn't do much...anything else it could be?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: November 15, 2004, 12:27:50 am »
It's possible the yoke could have come loose and rotated slightly.
DaemonCollector
« Reply #4 on: November 15, 2004, 05:42:33 pm »
So how would I repair it, can I rotate it with the monitor on to see if that is the problem?
Ken Layton
  • Guru
  • Technician
« Reply #5 on: November 15, 2004, 06:44:01 pm »
While wearing heavy leather gloves, loosen the yoke clamp screw and rotate the yoke slightly while the monitor is on. WARNING: your hands will be near the high voltage area. Don't kill yourself.  :o
DaemonCollector
« Reply #6 on: November 15, 2004, 11:35:59 pm »
oy....im might wait a bit before trying this...its not that bad of an angle...
