Author Topic: Monitor dimness problem, can I replace the chassis with a different one?  (Read 1560 times)
sfetaz
  • Last login:March 11, 2008, 12:58:28 pm
  • DDR4LIFE
    • Home of DDR Machine Rentals and The Madison Square Garden DDR Championships!
On the DDR Machine I just got the monitor is dim.  There is no contrast control and we have tried all others with no success on making it look right.  It is a 29inch Samsung tube and a Hong Eun Chassis for 29 inch.  I do not know if I can get a cap kit for this chassis, but if that does not work, is it possible to purchase a different chassis for a different 29 inch monitor and use that with the Samsung tube, or is that ever possible?
And if a specific cap kit cannot be found is there a way to get all the capacitors needed or a list of them without writing everyone down on a piece of paper since we may miss some?
« Last Edit: November 12, 2004, 07:15:36 pm by sfetaz »
Ken Layton
  • Guru
  • Technician
Re:Monitor dimness problem, can I replace the chassis with a different one?
« Reply #1 on: November 12, 2004, 07:17:31 pm »
You have a Wells-Gardner monitor. I don't remember the specific model that DDR uses, though.
sfetaz
  • DDR4LIFE
« Reply #2 on: November 12, 2004, 07:19:10 pm »
How would you know if this is Well Gardner if the chassis says Hong Eun and the tube says samsung?  Also usually DDR machines default to Toshiba but this was a korean machine and also may have a replacement monitor already, I am unsure of that though.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: November 12, 2004, 11:48:52 pm »
Sounds like you have a Wells-Gardner Korea monitor made at Wells' Korean plant.
