Author Topic: Multiple Rom Paths in Mamewah  (Read 2138 times)
zubel
  • Newbie
  • Last login:November 11, 2004, 07:14:59 pm
« on: November 11, 2004, 07:21:47 pm »
Hi all,
I 'm trying to use multiple ROM directorys in MAMEWAH 1.52.
In my mame.ini file I set
"rom_path   c:\mame\roms\horizontal;c:\mame\roms\vertical"
But MAMEWAH can't find any ROM anymore.
If I delete one of the path, it works.
If I start M.A.M.E. with the option:
"-rp c:\mame\roms\horizontal;c:\mame\roms\vertical"
manually, Mame will find the Roms in both directorys.
How can I set Mamewah, to search more than one directory for Roms ?
Thank You for Help.
Zubel
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:Multiple Rom Paths in Mamewah
« Reply #1 on: November 12, 2004, 08:21:45 am »
  You need to set your multiple rom paths in MAME's mame.ini file, not MAMEWAHs.  Look in your MAME directory and find a mame.ini file there.  If there's not one you'll have to create one by opening up a command prompt, navigating to your MAME directory and running mame -cc .
  Read the MAME documentation on how to set up multiple ROM paths in there.
  Don't forget that when you do this, you can no longer use MAMEWAHs list_generation_method of rom_folder_vs_listxml.  You need to change the list_generation_method to verifysets_vs_listxml.
  -Steve
