Author Topic: how to set the videocard for 15KHz?  (Read 3158 times)
deflux
  • Newbie
  • Last login:September 20, 2002, 02:43:31 am
« on: September 20, 2002, 03:13:02 am »
I have a real arcade monitor and want to use it for mame. From what i read, the arcade monitor can only handle 15KHz, anything higher and it can damaged the screen.
I heard ArcadeOS can set some videocard to 15KHz, but my card does not seem to be on the supported list. http://www.mameworld.net/pc2jamma/mamemon5.html
I have an old PCI S3 trio and a PCI 3DFX voodoo4 4500.
is there any other way to set my videocard to output 15KHz safely? or must i hunt down an ATI rage card?
Thanks in advance.
rgardjr
  • Last login:December 05, 2002, 06:03:32 pm
Re:how to set the videocard for 15KHz?
« Reply #1 on: September 20, 2002, 02:58:47 pm »
Check out advance mame http://advancemame.sourceforge.net/
May have more compatibility for your cards.  The cards it's compatible with can be found here:
http://advancemame.sourceforge.net/card.html
mhoward211
  • Last login:April 09, 2003, 10:31:25 am
« Reply #2 on: September 20, 2002, 04:06:15 pm »
The following two sites are great help for getting started with getting your arcade monitor to work with Mame.  Check a few threads down for the Windows On... thread as well.  Your best bet might would be either get the Trident Blade t64 card ($30) or one of the supported ATI cards.
http://www.msu.edu/user/jonesdes/
http://homepage.ntlworld.com/andrew.lewis5/arcade/monarc.htm
