Author Topic: Williams driver speed update?  (Read 2358 times)
SirPeale
  • Green Mountain Man
« on: November 08, 2004, 08:26:44 pm »
I was using Mame .36 on a cabinet.  One of my favorite games to play is Robotron.
It would slow down heavily when there was a lot of action on screen, predictably.  I mean, it's only running on a 450 MHz processor.  It's actually 550, but I can't clock it any higher on the board it's on.
So for giggles I put .84 on, because I'm looking to test for some other games (like Uo Poko).  Uo Poko is slow, but I figured it would be.
For fun, I launch Robotron, expecting it to be slow.  Instead, not only is it mirror smooth, but has *none* of the slowdown in the busy parts like it used to.  It's actually a *pleasure* to play.
When did this driver get optimized?
krick
  • Gotta have blue hair.
Re:Williams driver speed update?
« Reply #1 on: November 08, 2004, 10:41:25 pm »
Actually, there was a thread on the MAME forum where people were complaining about them removing the slowdown.
Supposedly, the real arcade machine had a certain amount of slowdown on the later levels that you could exploit to give you a little more time to react.
With that gone, the game is much harder at later levels and people are having trouble getting the same high scores.
I'll try to find the thread.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
krick
« Reply #2 on: November 08, 2004, 10:45:46 pm »
Hantarex Polo 15KHz
paigeoliver
  • Awesome face!
« Reply #3 on: November 09, 2004, 01:41:25 am »
Hmmm, this is GOOD NEWS! This means that I must actually be a true Robotron master, if I can get a half million on mame or on my JAMMA multi-williams board (which is certainly mame as well), then that means I could probably go forever on a real machine!  ;D
« Reply #4 on: November 09, 2004, 05:24:56 am »
Found it on mameworld's mametesters forum:
http://www.mameworld.info/ubbthreads/showthreaded.php?Number=2793
At least Aaron showed some interest...I wonder if he ever got round to looking at it?
SirPeale
« Reply #5 on: November 09, 2004, 07:49:35 am »
Yeah, I remember that.
The slowdown I was referring to was in FPS, where is would go from 60 FPS to 45 when there were a lot of moving objects on screen.  That was for .36.  It's not doing it for .84.
2600
« Reply #6 on: November 09, 2004, 08:30:35 am »
According to Maws, the driver hasn't been touched for a while, .24. You may be experiencing benefits of a newer mame core, how things are displayed, directdraw, and/or compiler optimizations
SirPeale
« Reply #7 on: November 09, 2004, 09:38:55 am »
Def. not DirectDraw, it's a DOS setup.
MAWS is a little off I think, I submitted (and was accepted) a couple of revisions for this driver back a few versions.  It didn't have anything to do with gameplay, though.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #8 on: November 09, 2004, 10:22:14 am »
Didn't Aaron or someone optimize all the CPU cores recently? I think it happened around 0.78. Maybe the M6808 code has been cleaned up too much? ???
« Reply #9 on: November 09, 2004, 10:43:56 am »
Maybe something to do with the 'watchdogs' I read about a while ago...IIRC it caused problems for some other games too.
SirPeale
« Reply #10 on: November 09, 2004, 10:46:56 am »
I certainly wouldn't call this a problem!
« Reply #11 on: November 09, 2004, 11:01:11 am »
Right, I meant the 'removal of slowdown that was present in the original' (bad emulation) problem.  Thinking about it that probably occurred before the major watchdog stuff tho...
