Author Topic: Upgrading mame, BIG loading slowdown  (Read 2053 times)
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« on: November 08, 2004, 05:13:31 pm »
I'm updating from .78 to .88 with each rom set upgrade, mame windows command line program, and using clrmamepro for .88.
After playing with a couple things, I wanted to make sure it was actually WORKING before I set clrmamepro loose on the whole system (which takes a while) I loaded Dig dug. Took probably 10-20 seconds (before was 3-4 seconds)
Loaded Pengo and it took about 20-30 seconds (3-4 seconds before)
I could be WAY OFF on those times, but that's sure as hell what it felt like. I tried using the pentium pro optimize as well and that didn't help much (if any)
Using a P3 - 800mhz with around 512mb SDRAM - windows XP
BYOAC users get 5% off with coupon code byoac5
lokki
  • Last login:May 05, 2025, 06:18:51 pm
Re:Upgrading mame, BIG loading slowdown
« Reply #1 on: November 08, 2004, 05:19:09 pm »
Disable validity checks
skip_validitychecks 1
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #2 on: November 08, 2004, 05:22:59 pm »
My love is like woah.
-Steve
Sylentwulf
« Reply #3 on: November 08, 2004, 05:27:25 pm »
I'll give that a try, my mame.ini file didn't change though, and I didn't have them disabled before. (Clrmamepro is running now, so it'll be awhile. I'm overhauling my romset.)
« Reply #4 on: November 08, 2004, 06:16:59 pm »
It will speed things up.  skip_validitychecks was only added in v0.88, so do a 'mame -cc' for it to show up.
Sylentwulf
« Reply #5 on: November 08, 2004, 08:46:00 pm »
Ahh, I added the line in the mame.ini file and it seems to be doing a lot better now, still seems a BIT slower, but not much. Thanx!
cdbrown
  • Bowowow
« Reply #6 on: November 08, 2004, 09:09:05 pm »
you should rename your old mame.ini to something else then do mame -cc for each release of mame.  That way you won't miss out on any extra options which may have been added since the last release.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #7 on: November 08, 2004, 11:05:25 pm »
Actually, just do a mame -cc.  It will add int he new commands if there are any.
screaming
  • Registered lUser
« Reply #8 on: November 09, 2004, 08:27:23 am »
  ...and keep your old settings the way they were.
-Steve
