Author Topic: Ultimarc MiniPac Question.  (Read 1277 times)
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« on: November 07, 2004, 11:12:48 pm »
I just purchased  the 'normal' MiniPac $29 with the intent of having only controls for 2 joystick + 10 buttons.  I was given a happ trackball.  Now I would like to hook that up also.
Do I need to pick up a opti-pac or are the connectors 33-38 active for me to hook into?
Teamwork - A group of people running around doing what I say.
Tiger-Heli
    • Tiger-Heli
Re:Ultimarc MiniPac Question.
« Reply #1 on: November 08, 2004, 06:24:40 am »
The connectors should be active.  Definitely try to use the MiniPac before buying an opti-pac.
You could also buy www.oscarcontrols.com mouse hack instead of the opti-pac, but you should be able to use the mini-pac.
