Author Topic: Getting from Custom List back into Main List in Mamewah  (Read 1638 times)
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
« on: November 07, 2004, 03:21:31 pm »
A real quickie for someone :) I have searched, but I assume it's never been asked!
How do you get from the custom lists (what's the key combination?) back into the 'Main' list. I've never used the custom lists, so I've no idea. A friend of mine has strayed into the custom lists and can't figure out how to get back to his main Mame (EMU 1) setting where all his games are.
I've no idea as I have only ever stuck to the main list, and have never needed anything else.
TJ
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
jcrouse
    • CPViewer
Re:Getting from Custom List back into Main List in Mamewah
« Reply #1 on: November 07, 2004, 03:31:59 pm »
Press the "2" key to bring up the options menu.
Arrow down to "Select Game List".
Arrow down to the desired list.
Press "1"
Alternatively, you can configure keys in the default.ini file in the "ctrlr" folder to cycle through the game lists or select a gamelist. Look for "select_gamelist", "next_gamelist" and "previous_gamelist".
Good Luck,
John
Halo
  • I'm a lamer!
« Reply #2 on: November 07, 2004, 03:34:39 pm »
Thanks very much John!
TJ
brihays
  • Newbie
  • Last login:November 07, 2004, 04:33:06 pm
« Reply #3 on: November 07, 2004, 04:34:53 pm »
Hi Tony, finally got registered.
The problem I have is the 2 key doesn't perform the function it used to. ie when I press it I don't get the menu up anymore? it seems to do exactly the same thing as the 1 key now  :-[
Halo
  • I'm a lamer!
« Reply #4 on: November 07, 2004, 04:41:44 pm »
Hi mate :)
As the '2' key is mapped to the cabinets 'P2' button, try there - I'm drawing a blank as to why the '2' key wont select the desired option ... I'm not sure where you can check that keys action / setting , perhaps someone here can help :)
jcrouse
    • CPViewer
« Reply #5 on: November 07, 2004, 04:46:12 pm »
look in the default.ini file in the ctrlr folder. It holds all the key mappings.
Good Luck,
John
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #6 on: November 08, 2004, 11:28:33 am »
Also by default "3" will cycle through your lists.
