Author Topic: mamewah + clones  (Read 1332 times)
dreamcastninja
  • Last login:December 27, 2013, 11:47:22 pm
  • galaga... is where it's at!
mamewah + clones
« on: November 06, 2004, 12:55:13 pm »
anyone know how to remove the clones all at once from all the lists you have in mamewah instead of removing individual games from the lists since that takes forever?
::also i just copied the outrun roms and it wont recognize them... it's weird::
jcrouse
    • CPViewer
Re:mamewah + clones
« Reply #1 on: November 06, 2004, 03:22:17 pm »
dreamcastninja
Re:mamewah + clones
« Reply #2 on: November 06, 2004, 11:33:22 pm »
Thanks for the help. I've already made custom lists using catver.ini
BUT
is there an option to remove all the clones or do I have to manually take them all out? i was trying to avoid doing it one by one...
jcrouse
    • CPViewer
Re:mamewah + clones
« Reply #3 on: November 07, 2004, 12:36:44 am »
There is an option. After you create your empty file, go into mamewah. choose, select custom list, selct your new list, then choose custom list options, then choose generate custom list. The top option will be display clones. :)
Good Luck,
John
dreamcastninja
Re:mamewah + clones
« Reply #4 on: November 07, 2004, 01:17:52 am »
hgmmz i've tried that but it didn't work i'll fire it up and try it now
dreamcastninja
Re:mamewah + clones
« Reply #5 on: November 07, 2004, 01:19:57 am »
i feel dumb
it was right there
hahaha
THANKS SO MUCH!
jcrouse
    • CPViewer
Re:mamewah + clones
« Reply #6 on: November 07, 2004, 01:24:25 am »
Glad to help. FWIW, make sure you check out the MameWAH message board at http://www.mameworld.info/ubbthreads/postlist.php?Cat=&Board=arcadeospc2jamma
Enjoy,
John
