Author Topic: Need help with ARCADEVGA setup  (Read 1166 times)
vettetek
  • Last login:July 18, 2025, 09:07:37 pm
« on: November 04, 2004, 08:20:25 pm »
I just purchased (used) an arcadevga card - no drivers. I am using a fresh install of xp and an 34" sharpimage arcade monitor. I was able to find the latest drivers on ultimarc, but when I try to run them it says not compatible. I tried "manually" installing them with the device manager, and they seem to work, but I cant adjust the resolution with the "galaga" Icon. I select another resolution, but it always defaults to 640x480 at 16bit.  The card I bought has the green heatsink on it. I believe its the 7200 series card. Im not sure though. Does anybody have some documentation on setting this thing up or the drivers for the "old card"? I did try a search on this forum, but I came up empty.
~V
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re:Need help with ARCADEVGA setup
« Reply #1 on: November 04, 2004, 11:13:16 pm »
Go to the ultimarc forums, and there are a few links for the original arcadevga drivers.
The original board (7000 series) has 2 db15hd connectors.
Try this one.
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=731&page=7&view=expanded&sb=5&o=&fpart=1&vc=1
Later,
dabone
vettetek
« Reply #2 on: November 05, 2004, 05:37:21 pm »
Thanks Dabone!
Thats just what I needed - at least for the drivers - now on to the other problems -but thats another post!
~V
