Author Topic: Testing control mapping to keyboard  (Read 1164 times)
WonderMellon
  • Last login:February 10, 2019, 12:41:23 am
« on: November 04, 2004, 12:40:16 pm »
I have 1 joystick and 1 set of buttons wired and hooked up to my keywiz.  Unfortunatly I seem to have destroyed the disk that came with the encoder.  I need to see what keys on the keyboard the controls are mapped to.  Is there a program out there that will tell you what keys are pressed?
I can use notepad for the alpha keys, but that won't show me the arrow and control keys.
Tiger-Heli
    • Tiger-Heli
Re:Testing control mapping to keyboard
« Reply #1 on: November 04, 2004, 01:27:13 pm »
Well, the keywiz doesn't save custom settings in memory, so if you aren't loading the keywiz software at bootup, you can re-start you machine and the keys will be mapped to: http://www.mameworld.net/tigerheli/encoder/inputs.jpg
If you are using the software, I think it will show you the keyassignments, or you can use Ghostkey, KeyJammin, KeyScan, etc. from http://www.arcadecontrols.com/arcade_downloads.shtml#Utilities
WonderMellon
« Reply #2 on: November 04, 2004, 04:13:45 pm »
Thanks Tiger-Heli!  I was looking in the interfaces section.  I completely missed the utilities section.
