Author Topic: arcadevga ate my login  (Read 1233 times)
paigeoliver
  • Awesome face!
« on: November 03, 2004, 09:40:14 am »
Ok, just installed arcadevga on a windows xp based computer. It was working good. Used it a few times, etc.
I switched it to 640x288 resolution, now when I boot it I am brought to the login screen but without any accounts to choose from!
What in the world am I supposed to do now?
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re:arcadevga ate my login
« Reply #1 on: November 03, 2004, 09:43:56 am »
Press ctrl-alt-del.
Then login as adminstrator.
Later,
dabone
turboc
  • Last login:October 30, 2004, 08:27:55 am
« Reply #2 on: November 03, 2004, 07:18:52 pm »
Windows XP will autologon as long as there is only one account.  Once you logon as Administrator, open the user manager and check to see if a new account has been created that cannot be interactively logged on.  For example, installing .NET framework will add a new account.
You could also use tweakxp to autologon if necessary.
wboy
  • Last login:November 03, 2005, 05:09:19 pm
« Reply #3 on: November 04, 2004, 05:11:58 am »
booting into safe mode will show the login prompt, with your default acount name most likely showing.  Not sure if ctrl-alt-del works at the welcome screen is enabled in the user account control panel options...
That should get atleast get you in to fix things up.
« Last Edit: November 04, 2004, 05:13:43 am by wonderboy »
