Author Topic: Wiring up a TV to turn on?  (Read 1096 times)
dmish82
  • Last login:September 09, 2005, 10:31:40 am
  • "What is this? A center for ANTS?!?!?!"
« on: November 01, 2004, 01:11:52 pm »
Hi,
I have a TV i bought that does not power back on when power is cut off using a Smart strip or with just a regular outlet (only TV i could buy that would fit in my cabinet). It is a 27" Sansui and I was wondering if anyone has tried or knows of a way to wire up the TV to turn back on after power is cut off to it since the Smartstrip is unable to turn my particular TV on. I was thinking of something along the lines of using a relay and connecting it to the power switch somehow but who knows. Thanks.
Shifty
  • Last login:December 21, 2008, 02:34:15 pm
Re:Wiring up a TV to turn on?
« Reply #1 on: November 01, 2004, 04:31:20 pm »
Depends, is the power button a momentary switch? Or on/off? Using a relay would work fine for on/off, might be a bit of a bugger to get working with a momentary switch. When you turn it on, it would have to send a short signal, and then when you turn it off, another short signal.
TalkingOctopus
    • My Arcade
« Reply #2 on: November 01, 2004, 05:22:34 pm »
I had the same scenario with the smart strip and my TV.  I ended up buying a cheap universal remote and taking it apart, connecting the power button of the remote to an arcade pushbutton.  Then I extended the IR emitter to in front of the TV so when you press the pushbutton attached to the remote it turns on the TV.
normchorus
  • Last login:May 15, 2007, 01:28:32 pm
« Reply #3 on: November 01, 2004, 07:23:00 pm »
Or you could go with the ultra low-tech, yet cool and effective way: http://www.ysib.com/zoom/monitor.html
