Author Topic: Help!!! I need a chassis!  (Read 2155 times)
deliciousfeet
  • Last login:October 31, 2004, 04:30:09 pm
« on: October 31, 2004, 04:43:02 pm »
I have a Revolution X arcade model that has NO chassis!
The game has an RCA picture tube with the following identifying numbers...
Tube Type-A63ADT10X05
Serial#D-NHF2C380
First, are these usefull #s when looking for the chassis
in question? If not,what #s would I want to look for?
Second,Where would one go to find the chassis when and if the correct one is established...Ebay?
MonitorGuru
Re:Help!!! I need a chassis!
« Reply #1 on: October 31, 2004, 05:35:44 pm »
Thats a 25" tube (63 centimeters per the tube number)
You need to check the number of pins on the back of the tube and the type of connector it has.
Go to 8liners.com's chassis page: http://www.8liners.com/datatech/monitor.html
and follow the instructions there to determine what chassis you need.
You can buy from 8liners or ebay, or you can pay a lot and buy direct from Happ and others
deliciousfeet
« Reply #2 on: October 31, 2004, 06:31:45 pm »
DUDE!!! You are the man!!!!I can't believe how quick that response was...appreciate the hell out of the help!Thanks much!!!!
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 31, 2004, 07:46:17 pm »
It would be helpful if you could post a picture of the rear area of your monitor to help identify what make/model it is.
deliciousfeet
« Reply #4 on: October 31, 2004, 08:41:10 pm »
No need...Gurus help was more than adequate,but in the future if a real stumper comes up I will remember your advice. Thanks once again!!!
