Author Topic: Changing Resolution Problems  (Read 1623 times)
Josh
  • Last login:February 04, 2018, 06:43:58 am
« on: October 31, 2004, 06:35:41 am »
I believe that my problem is screen resolution related.  It is currently set to 800x600 and I want it set to 640x480 I think.
When I go to change it I only get a choice of 800x600 or 1024x768
How can I get it to show 640x480?
Thanks for any help you can provide
Pee-Wee
  • Last login:July 14, 2005, 06:04:45 pm
  • I LUV ARCADE MACHINES!!!
    • DJJammi
Re:Changing Resolution Problems
« Reply #1 on: October 31, 2004, 11:41:29 am »
There is a program called "Power Strip", which can change the size of the screen , bypassing the windows files.
Please be careful not to damage your graphics card!, usualy, if it only has that option, thats the only thing it can do!, ( your monitor is the most important thing! ) , and just out of interest, you can buy a special card from Ultimarc that will make the monitor work safely.
James Lovegrove
DJJammi
www.djjammi.co.uk
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: October 31, 2004, 01:17:04 pm »
No, powerstrip is overkill for what you need.
Go to display properties, click advanced,  select the adapter tab, then click on list all modes then select 640x480x24 or 32.
Later,
dabone
