Author Topic: mamewah ctrl file and multiple keys  (Read 1567 times)
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« on: October 31, 2004, 12:04:36 am »
default.in icontains the following:
MENU_LOCK         "DIK_1 & DIK_2"
LAUNCH_GAME         "DIK_1"
LAUNCH_GAME_WITH_OPTIONS1   "DIK_LCONTROL & DIK_1"
LAUNCH_GAME_WITH_OPTIONS2   "DIK_LALT & DIK_1"
I thought that meant that to lock the menu you needed to depress both 1 and 2, to launch game with options 1 you need to press left control and 1, etc...
This doesn't appear to work though, left control by itself launches the game, and I can't figure out how to lock the menu
(mamewah v1.52, WinXP Pro, USB keyboard or KeyWiz)
Re:mamewah ctrl file and multiple keys
« Reply #1 on: October 31, 2004, 08:36:47 am »
Hmm, Left Control doesn't do anything for me, LControl+1 launches with the extra options as it should.
I agree about the menu tho, I think is is having a problem since both 1 and 2 are already used - the lock does work, try mapping some un-used inputs to it.
papaschtroumpf
  • Have a Cow!
« Reply #2 on: October 31, 2004, 09:51:18 am »
EDIT: nevermind it seems to be working this morning. I rebooted the cab but I can't see why it made a difference. Must have been operator error.
By the way, what the ctrlr entry for in mamewah.ini?
« Last Edit: October 31, 2004, 10:32:50 am by papaschtroumpf »
« Reply #3 on: October 31, 2004, 11:01:55 am »
You can use different configs, just like MAME (or MAME's old ctrlr ini files anyway).  So you can have multiple folders within \ctrlr (eg \hotrodse or \xarcade, maybe I should supply these as examples), and also emulator and list-specific configs.
This is massively overkill, as most people will only use the standard default.ini...I have multiple control panels so I thought list-specific ctrlr files would come in handy, but actually I just tend to use multiple inputs within the same ctrlr file (technically this is slower tho, but not noticable).
