Author Topic: Powering your cabinet  (Read 1945 times)
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« on: October 29, 2004, 07:13:03 pm »
How does everyone get power to their cabs? I made a small wall plate with an IEC socket and switch for mine but dumped that idea because it was too ugly. I don't really want to just have a mains cable running from a hole in the cab. Any ideas on what to do?
I love the life I lead. I wish I could afford it.
terrahwk
  • Last login:October 16, 2013, 05:47:23 am
  • mmm.. donuts
    • nucleardog.net
Re:Powering your cabinet
« Reply #1 on: October 29, 2004, 08:44:13 pm »
During the design of my cabinet I was always intending to use a flush mains power socket. Umm.. sorta like this one:
http://www.seamarknunn.co.uk/catalog/items/item3700.htm
Maybe look at caravan/camper trailer stores?
In the end I just ended up with a mains cable running from a hole in the cab. ;)
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #2 on: October 30, 2004, 02:55:13 pm »
Yeah, I'd have to say, no matter how you dress it up, it's going to basically be a cble coming out of a hole in the cab :)
I know my jamma cab has a metal plate that is inset into the wood, and knotted behind the metal plate so it doeesn't get pulled out, but with a home cab,m theres just not much of a point since you probly won't have people beating the crap out of your cab and pulling it around your living room by the cord....
BYOAC users get 5% off with coupon code byoac5
Craig
« Reply #3 on: November 06, 2004, 06:42:28 pm »
What have others done?
danny_galaga
  • Last login:Yesterday at 05:59:46 pm
    • dans cocktail lounge
« Reply #4 on: November 08, 2004, 12:00:39 am »
used one of these. forgotten what it was from, a dead monitor or something. i had to make the hole a bit bigger to fit it though but underneath a cocktail it doesnt matter
danny_galaga
« Reply #5 on: November 08, 2004, 12:04:06 am »
a view from inside...
there is probably a version that allows this sort of mounting properly. like i say, i took it off something else. just remembered, it was from the monitor IN the cab. nothing like recycling the bits  :D. it was flush mounted to the pcb. you would just need one that is designed to point UP from the pcb.
edit: a dead power supply might have the right shape...
« Last Edit: November 08, 2004, 12:08:47 am by danny_galaga »
Craig
« Reply #6 on: November 08, 2004, 12:18:57 am »
Thanks for the reply. I am impressed by your safe wiring by using heatshrink tubing etc. ;-)
danny_galaga
« Reply #7 on: November 08, 2004, 12:39:06 am »
the wires to the right go to some microswitches for the rotating monitor. even with the heatshrink i STILL managed to get zapped a few times adjusting them!!
paigeoliver
  • Awesome face!
« Reply #8 on: November 08, 2004, 03:26:06 am »
I have actually started modifiying my real cabinets this way. Whenever I need to replace a cord I do it that way now. Makes it so much easier to deal with.
