Author Topic: IPAC4 woes updated  (Read 1973 times)
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
IPAC4 woes updated
« on: October 27, 2004, 09:42:21 pm »
hello
just got ipac4
it installs with no wires fine into ps2 or usb
problems starts when i start connecting wires (probally connected etc..)
all my usb devices from the hub start disconnecting one by one..
it's an old asus a7v mobo...  maybe i update bios?  is there too much power going to this usb (4 port hub, light, 3 devices)
i duh know
i'm confused
« Last Edit: October 28, 2004, 06:31:11 pm by mcdo15 »
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
Re:IPAC4 woes
« Reply #1 on: October 27, 2004, 09:46:47 pm »
hello
just got ipac4
i duh know
i'm confused
Does your USB hub have a separate power adapter for it or does it draw its power off the motherboard? If it just draws it off the motherboard I would suggest a hub with an external power supply.
-FTen
« Last Edit: October 27, 2004, 09:47:11 pm by ften »
mcdo15
Re:IPAC4 woes
« Reply #2 on: October 27, 2004, 09:54:45 pm »
well..i tried with the usb port connect (w/pins) from mobo and i just tried the built in usb in the rear of the mobo....
both are doing the same thing
i had an ipac 2 successfully workingi but i traded in for an ipac 4
unsure of power siuation...i assume i hooked up pins in right order cause the usb devices connected to it works
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re:IPAC4 woes
« Reply #3 on: October 28, 2004, 10:12:55 am »
If you connect switch wiring to the I-PAC, nothing should happen at all, because unless the switches are pressed, the wires don't actually go anywhere, they are just open-circuits at the end.
So this would suggest that there is some problem with the wiring and it is not in fact open circuit but shorted or some other problem.
The self-test LED on the I-PAC can instantly show such problems.
I can assist if you drop me an email: andy@ultimarc.com.
mcdo15
Re:IPAC4 woes
« Reply #4 on: October 28, 2004, 11:01:39 am »
i figure i'll ask here first Andy...as great as a help you have been to me...i didnt want to bother ya this time.
Im gonna buy a usb hub with self power...  another poster mention he had simliar experience... everything usb just kinda freaks out after i make a single connection via usb.  PS/2 i didnt detect it......i try when i get home from work..
thanks
mcdo15
Re:IPAC4 woes updated
« Reply #5 on: October 28, 2004, 06:32:06 pm »
Okay
so i brought a self powered usb hub (belkin)
and it's still not detecting the ipac correctly
can it be the OS?  win mce 2k4 sp2
maybe i talked to soon...finally..i got recongized by OS
now..let me do my 1 wire test (thats where is went wrong before)
« Last Edit: October 28, 2004, 06:49:37 pm by mcdo15 »
mcdo15
« Reply #6 on: October 28, 2004, 07:02:18 pm »
screw technology...i think i'm gonna quit 80% into this progect  >:( >:( >:( >:(
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #7 on: October 28, 2004, 07:08:15 pm »
Awww man! You can't quit now. Give Andy a shot at the problem.
Good Luck.
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
mcdo15
« Reply #8 on: October 28, 2004, 11:16:48 pm »
Good Luck.
well, we been talking about various problems i've been having
i just figured i'll ask here first
i sent him an email... i hope nothing is wrong with board...i hate mail and recieve stuff from far away (takes to long) and dhl can be annoying
