Author Topic: Power Button Idea. Untested.  (Read 2125 times)
JesterDEV
  • Last login:November 25, 2010, 05:29:21 pm
  • OU812?
    • Jester's Temptation
« on: September 15, 2002, 11:13:10 pm »
I was just messing around while watching tv, and attatched my power button from my pc to a button that came with my cab with super glue. I used a leaf button(I think thats what its called). I just bent some of the unused connecters down and super glued it in between the leafs(?). Now when I press the button, it also presses the power button! I also had to spread the leafs a bit so it wasnt always pressing it down.
I havent tested it out yet, but I think its going to work. Anyway, its just an idea for those wanting some sort of outside the cab power button. I'll get some pics later if anyone wants them.
Great big gobs of greasy grimey gopher guts.
1UP
  • Token Junkie
    • 1UPArcade
Re:Power Button Idea. Untested.
« Reply #1 on: September 16, 2002, 02:39:21 am »
I can't quite figure out what you're describing here...  But if you need an external power button, it's easy to just run extension wires from the PC  power button to a button anywhere on your cab, especially if you're using an ATX case.  A regular arcade button should work.  I wouldn't suggest super glueing your wires together, solder works much better.   ::)
My other job...
JesterDEV
  • OU812?
« Reply #2 on: September 16, 2002, 02:35:12 pm »
And here I was thinking I did something ingenious!
Atleast I was impressed with it.  :P
But yes your right, it would be better to do it the
way you explained.
