Author Topic: Where to mount IPAC??  (Read 1955 times)
dmish82
  • Last login:September 09, 2005, 10:31:40 am
  • "What is this? A center for ANTS?!?!?!"
« on: October 24, 2004, 10:57:15 am »
this is probably a question that is a matter of personal preference, but do most of you mount your IPAC in the control panel box or on the inside of the cabinet? I was going to mount it into the C/P box but thought that from slammin joysticks and buttons, there might be too much vibration over time that wouldn't be great for the IPAC. Anywho, let me know what you guys think. Thanks in advance.
koolmoecraig
    • My Intervention
Re:Where to mount IPAC??
« Reply #1 on: October 24, 2004, 12:50:59 pm »
You will save yourself a hell of alot of headaches by mounting it on the control panel. No long wires, no need to disconnected everything when removing the panel, etc.
Brogner
  • Last login:March 03, 2025, 12:58:08 am
  • If I could just get another quarter
« Reply #2 on: October 24, 2004, 05:00:58 pm »
I've done both but prefer it on the CP. there wasn't enough room on the cp of my vertical cab to install it there. koolmoecraig is right about the long wiring and flexibility in removing the CP.
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #3 on: October 24, 2004, 05:23:16 pm »
The only reason to mount it in your cab IMO is because you are going to have interchangeable panels (like me ;)).  And if you do mount it in your cab, you should come up with a good way to disconnect it.  I used flat ribbon cable to the ipac, and then DB25 ends so I can quickly disconnect the panels.
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #4 on: October 24, 2004, 06:20:32 pm »
Yeah, single CP, mount it in the CP box, there should be PLENTY of room in there.
Swappable CP's, you need to mount it in the cab unless you want to buy multiple IPac's :)
BYOAC users get 5% off with coupon code byoac5
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #5 on: October 24, 2004, 06:21:01 pm »
I just mounted it to the underside of the CP lid (no plans for removable/modular controls). Keeps the wiring cleaner, and prevents any wires getting snagged/tugged/moved.
whammoed
  • Last login:May 07, 2026, 10:56:39 am
  • Crack don't smoke itself
    • NiceMite
« Reply #6 on: October 24, 2004, 07:22:01 pm »
I mounted mine inside the cab because I have three panels on my cocktail.  I used molex micro fit 3.0 connectors to allow removal of the panels for maintenance.
