Author Topic: arcadevga and resolutions  (Read 3983 times)
big daddy
  • Last login:May 01, 2019, 12:16:13 pm
« on: October 20, 2004, 02:57:34 pm »
ok, so I have my arcadevga card and a betson imperial multi-synch monitor.  I want to make sure the games are all running at the resolutions that they're supposed to with that monitor.
I downloaded the avres utility off the ultimar site and ran it.  It put ini files in my mame/ini directory for each game and set a resolution that I understand to be the best match of a resolution that the arcadevga supports compared to what's documented in mame. (FYI - I selected the option in that util where the only options I allowed it to choose from where those that supported 60MHz refresh rates..not sure if that was a good thing or not)
Anyway, now I can run the games (all run without any problems) and I think they all look good.  So my question is, is that it?  Is the resolutions that the avres utility suggested the best match of the resolutions that my monitor supports?  Or are there some games that the mame documentation is wrong or the avres utility may just get incorrect?  If so, does anyone have a list of those that are different.
Like I said, I think it looks good, but when I first booted Simpsons without running the avres util,  I was "blown away" by how it looks and now after running the avres utility I'm not really "blown away" and I don't know if that's because the avres utility may have not setup something correctly or if it was just the initial "awe" factor that has since worn off after playing several games  :)  (don't get me wrong, it still looks great, I just didn't have that awe feeling after the resolution settings.)
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
Re:arcadevga and resolutions
« Reply #1 on: October 20, 2004, 03:03:05 pm »
i too had some mixed results with the res tool.
the tool sets the games for their closest to original settings, but the fact of the matter is ,you and i and everyone else are not running on original hardware. so those settings are not necessarily the best for us..
if ive learned anything so far....
the best res tool you have are your own two eyes
Enjoying the fruits of technological obsolescence one game at a time...
« Reply #2 on: October 20, 2004, 06:10:07 pm »
It is possible the tool may not always pick the best (tho I have no reason to believe it would not)...
Try temporarily renaming your simpsons.ini to something else, and run again - see if you can tell the difference.  You could try my Res. Tool from my site if you like - not saying it is better but it gives a more visual idea of what resolutions are being picked.
Dynagod: To some extent you are right (eg displaying vert games on a horz screen or vice versa), but most people using these tools *are* using original hardware, effectively anyway (ie 15khz screen) - so in theory the nearest res. to native will be the best.  Of course there are some exceptions, like medium res. games...
DYNAGOD
« Reply #3 on: October 21, 2004, 07:27:00 am »
as i stated in another thread about  the Res tool, my problems are more than likely a result of operator error, not the programs selections.
ive found that on every game i play, if i go into custom game options and force 60hz ,disable hardware stretch and lock all the syncs, i get a much brighter and superior image than the res tool alone.
koolmoecraig
    • My Intervention
« Reply #4 on: October 21, 2004, 08:56:43 pm »
How exactly do you force 60hz and lock all the syncs? Do I do that in the mame.ini file?
Thanks,
craig
DYNAGOD
« Reply #5 on: October 22, 2004, 02:45:10 pm »
i specify it in my front end.
i use Emuloader and you can create a custom CFG file by checkin or unchecking the desired boxes.
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
« Reply #6 on: October 22, 2004, 04:17:38 pm »
I've found Steve's ArcadeVGA M.A.M.E. Resolution Tool much better at picking the proper resolution than the AVRES tool on the Ultimarc site. It's easier to use, as well (although it needs a shorter name!  ;))
http://mamewah.mameworld.net/downloads.html
Kevin
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
pacman
  • Last login:October 01, 2007, 09:51:35 am
Re: arcadevga and resolutions
« Reply #7 on: March 21, 2005, 05:30:31 am »
One of you can kindly tell me why this Mame Resolution tool do not launch properly on my XP with AVGA 9200 ? I receive alway this bloody 'Run Time error 13 - Type Mismatch'!! Mamewah system file package is installed so I do not know what a hell is going on!! >:( >:(
KevSteele
« Reply #8 on: March 21, 2005, 07:45:56 am »
I used to get that problem occasionally with MAMEWAH - I seem to recall that deleting/replacing the .ini file (or doing a clean reinstall) sometimes worked. I can't be more specific right now, as my MAME cab is out of commission until my monitor is back up and running...  :'(
Kevin
pacman
« Reply #9 on: March 21, 2005, 08:32:13 am »
Hi KevSteele,
Which ini are you talking about ? Mamewah, Mame or any other ? :P
KevSteele
« Reply #10 on: March 21, 2005, 08:37:39 am »
Hi KevSteele,
When it happened to me in MAMEWAH, it was the MAMEWAH.ini file (older version of MAMEWAH). I suspect your problems with the MAME Resolution tool may be similar, but I can't confirm right now that the Resolution tool uses an INI file. I'd check and see if it does, and try deleting it and/or doing a clean reinstall (delete the current directory and reinstall).
Kevin
pacman
« Reply #11 on: March 21, 2005, 09:35:46 am »
Correct me if I am wrong but for teh last updated version of Mamewah (1.61) there is nothing to install...This is weird as I remember that previous versions need installing before.. ??? ::)
KevSteele
« Reply #12 on: March 21, 2005, 09:42:58 am »
Yeah, you just unzip to a folder. But you don't need to do anything with MAMEWAH to fix the MAME Resolution tool - I'm just posting about my MAMEwah experiences since I got the same error with MAMEwah and fixed it by replacing the .ini file with a "clean" copy.)
Kevin
pacman
« Reply #13 on: March 21, 2005, 09:46:53 am »
Ok I will give it a try and see...
Finger crossed.... :P
