Author Topic: mamewah and cpviewer hang  (Read 3093 times)
big daddy
  • Last login:May 01, 2019, 12:16:13 pm
« on: October 20, 2004, 12:21:35 pm »
I've configured cpviewer..has a mockup image of my control panel and the labels created.  I set it up with options to open with a C and close with an X.
I then configure it NOT to display on game startup in mamewah, but I do have it set in mamewah.ini so that when I press the key at the gameslist screen it should display.
So when I'm browsing the games I hit C and the CPViwer launches and it shows my control panel.  The problem is, when I push X (or any other letter) the cpviewer doesn't close.  I end up having to cntrl-alt-delete and end task to close it.
Now the wierd part is it behaved exactly as I described above the first time I tried it.  Then later when I tried it again it worked perfectly (C opened it and X closed it) and I was able to use it repeatedly.  But now it appears to not be working again (i.e. it opens correctly, but doesn't close).
Anyone have any suggestions?
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:mamewah and cpviewer hang
« Reply #1 on: October 20, 2004, 12:25:30 pm »
Maybe it's a focus issue? try hitting alt-tab, then X...
-Steve
« Reply #2 on: October 20, 2004, 02:21:52 pm »
Yeah, or click the mouse...
I assume you configured the X key in CPViewer?
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #3 on: October 21, 2004, 09:14:50 am »
I continually had the same problem with CPViewer.  I switched to Johnny5 and it has been much more stable.
big daddy
« Reply #4 on: October 21, 2004, 12:28:18 pm »
I've been searching around for johnny5 download and can't seem to find it.  Can someone post a link to it for me?
mahuti
« Reply #5 on: October 21, 2004, 02:18:13 pm »
I've had endless problems with CPviewer & recent versions of mamewah in windows 98. It doesn't like to read files in and out very well it seems.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #6 on: October 21, 2004, 05:30:21 pm »
Search is your friend: http://www.oscarcontrols.com/lazarus/files/johnny5_0.6beta.zip
jcrouse
    • CPViewer
« Reply #7 on: October 29, 2004, 08:37:08 am »
I'll look into the CPViewer focus problem this weekend. What exactly does it do? Also, I'm loading a Windows 98 box so I can test some of the issues that some users seem to be having with CPViewer and Windows 98 and generationg the games.ini file.
Thanks for the input,
John
« Reply #8 on: October 29, 2004, 09:44:51 am »
I had a problem the other day with CPVGeneric - any key should quit but I found occasionally (~1/5 times) it would not quit.  Clicking the mouse and then hitting a key would work, indicating that it had lost focus...
But it seems to work fine today, so maybe it was just me!  :-X
big daddy
« Reply #9 on: October 29, 2004, 11:19:20 am »
I'm not sure the problem I described in the original post is a focus problem.  Because even clicking with the mouse, alt-tab ing, etc...never gets me focus back where X will close cpviewer.  Not sure what's going on though, because like I said in the original post...it did work for a little while.
FYI - I'm running XP home and the previous version of mamewah (haven't upgraded to the latest yet).
jcrouse
    • CPViewer
« Reply #10 on: October 29, 2004, 11:24:07 am »
Did you configure an exit key in CPViewer under the Tools/Options menu?
John
big daddy
« Reply #11 on: October 29, 2004, 11:31:40 am »
yes, I configured the exit key to be X and the launch to be C.  I configured it in mamewah and when browsing the list of games I hit C and it opens ok.  But hitting X didn't do anything.  I tried this several times with the same affect.  Later in the day I had stopped and started mamewah for various reasons and tried again and it worked (C would close it).  I did it several times and it worked several times.  I shut the machine down that day and the next day tried again and it was hanging again (X wouldn't close it).
Not sure what the problem is though.   One thing I just thought of..is that exit key case sensitive?  Maybe I put a capital X in the options and the reason it was working for awhile was because caps locks might have been on?
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« Reply #12 on: October 30, 2004, 12:31:02 am »
same problem here with mamewah 1.51
is there a fix in 1.52?
I just resorted to opening the controls at game launch..never hangs there
