Author Topic: What type of speakers are you using in your jukebox?  (Read 7658 times)
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« on: October 20, 2004, 12:26:16 am »
I was wondering if anyone is using standard audio speakers or car audio speakers in their jukebox cabinets or do most people use computer speakers.
I am a bit concerned about using a 10" car audio subwoofer in my cabinet as it will be close to the monitor, about 12" away. The same for the main speakers although they will about 6 or 8 inches from the top of the monitor.
« Last Edit: October 20, 2004, 11:08:58 am by froggerman »
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
Re:What type of speakers are you using in your jukebox?
« Reply #1 on: October 20, 2004, 05:44:39 pm »
All fake.....
The game of money ........
You can use any type of speakers for your cabinet.
Main thing is the AMPlifier....Speakers or subwoofers are not associated with a sound quality if you got a cheap amplifier.
If it is a  normal standard PC monitor it will never effect any
more but be carefull about color gun. because there is
a megnatic waves intrupt between the monitor and speakers signels....
personally i recommend you to set your speakers over the top of your cabinet.
BLUE BIRDS FLY WITH BLUE BIRDS
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« Reply #2 on: October 21, 2004, 03:19:43 am »
I don't have a jukebox, but if I did, I'd use 4x 8" woofers + tweeters and no sub woofer and have a 200W amplifier. Lose the sub woofer you really don't need the bass for a jukebox project.
I love the life I lead. I wish I could afford it.
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #3 on: October 21, 2004, 10:00:41 am »
I'm using 10 watt stereo speakers in the jukebox cabinet itself, but most of the time I won't use them at all because I'm going to run a line out to my surround sound.
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
« Reply #4 on: October 21, 2004, 11:04:49 am »
I'm using Dayton in wall speakers from Parts Express.    They sound good, are paintable and easy to mount in a jukebox.
Space Warped by Someone
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
« Reply #5 on: October 22, 2004, 06:01:36 pm »
I used a set of Logitechs for my cabinet as a set of car speakers distorted the monitor from a foot away and through 30mm of MDF.
depends on how loud you want the volume to go I suppose as to what amp/speaker combo you use.
Craig
« Reply #6 on: October 22, 2004, 06:21:33 pm »
Why would you use tiny speakers with a jukebox? The whole I idea of a jukebox is to be BIG and LOUD isn't it?
markb
  • The One and Only.
« Reply #7 on: October 22, 2004, 09:38:59 pm »
Maybe in Australia where your nearest neighbour is 4km away you can have really loud music , but here in England my neighbour sleeps about 4ft from my Jukebox. ;D
Seriously though I left a audio out plug so I can connect it into my main amp if needs be which would probably shake the house down if I ever turned it up full.
froggerman
« Reply #8 on: October 26, 2004, 11:36:34 pm »
Interesting experience with the car speakers. I was afraid that might be the case. I will have to do some tests with my monitor. Otherwise, shielded computer speakers.
BARD
  • Newbie
  • Last login:October 28, 2004, 04:17:26 pm
  • Let's Think About It. . .
« Reply #9 on: October 28, 2004, 04:23:34 pm »
Automobile speakers are usually 4 ohm instead of 8 ohm impedance.  So, you will have to watch the load impedance using 4 ohmers.  Strap your jukebox amp terminals accordingly.  Some home stereo amps can handle 4 ohm loads, others can't.  Check it out.
Shielded (PC type) speakers normaly having  bucking magnets and mu-metals cans over the magnet asy on the rear of the  speaker.  I wouldn't place them any closer than 6-8 inches from a CRT.  The electron gun emission gets deflected and the purity goes nuts!  Unshielde speakers shoudl be a good 18 inches away to avoid any serious effects.
« Last Edit: October 28, 2004, 04:38:07 pm by BARD »
