Author Topic: Stainless steel CP  (Read 1468 times)
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
Stainless steel CP
« on: October 16, 2004, 05:13:55 pm »
I've got access to a CNC water jet cutting tool (plus a brake press for bending metal).  Anyways, I made an Autocad drawing and cut my panel out of stainless steel.  My plan is to cover it with the Happ black vinyl, but it looks kind of cool in stainless.
There were some errors in the cutting - does anyone know how to tell the CNC machine to cut the button and screw holes from the inside of the lines?  Because of the errors, this one is definately getting covered, but maybe I'll do another one and do a comparison.
« Last Edit: October 16, 2004, 05:14:57 pm by daeven »
AmericanDemon
  • Last login:February 27, 2026, 01:01:31 am
  • Still an AmericanDemon
Re:Stainless steel CP
« Reply #1 on: October 16, 2004, 06:23:47 pm »
It varies between softwares.  My recommendations is to reduce the size of the hole so that it matches your need.
Pieman2004
  • Last login:July 15, 2009, 11:29:57 pm
« Reply #2 on: October 16, 2004, 06:29:02 pm »
I also cut mine out with a automated plasma cutter. I imagine it's about the same. I just made the holes smaller than they need to be, because where the holes start is the same place they finish and it makes a notch there. If you end up needing bigger holes you can just drill em out.
