Author Topic: De-soldering techniques  (Read 2662 times)
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
« on: October 15, 2004, 07:36:07 pm »
OK, I know how to solder a cap kit, and I've worked around small electrical components plenty, but how the fark do you guys remove enough of the solder on a flyback to get that bugger off?  Sawzall?
I know you're going to tell me that my $0.99 bulb-style solder sucker is insufficient for the job.  Go ahead.  Please just tell me what I should be using.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re:De-soldering techniques
« Reply #1 on: October 15, 2004, 09:27:47 pm »
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=64-2090
Works for me.
Later,
dabone
Edit by moderator: you forgot your URL tags around the address, that's why it wasnt' working before.
« Last Edit: October 15, 2004, 10:56:26 pm by Peale »
daeven
  • Llama this!
« Reply #2 on: October 17, 2004, 12:04:21 am »
That de-solder braid did the trick.  That just finished one repair project that's been on my list for a while.  My wife didn't appreciate having to stand there with the fire extinguisher while I powered it up.  Thankfully it was unnecessary since it works!
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« Reply #3 on: October 17, 2004, 10:41:42 am »
hahahahahahahaha...
Witchboard
« Reply #4 on: October 18, 2004, 01:47:37 pm »
I remember the first time I attempted to desoldered something.  I had one of those desoldering irons with the rubber ball on top that was built into the tool.  I melted the solder, pushed the bulb and blew solder all over the place.  I was like, "SON OF A ....!"  Mental note:  Squeeze ball before putting desoldering iron to joint.  ;D
exibar
  • Last login:January 02, 2025, 11:38:59 pm
  • I'm the creator of Exibar's Lair!
« Reply #5 on: October 18, 2004, 08:39:07 pm »
  rEminds me of the time that I was starting an engine that I knew was badly out of time, I told the wife "when the carberator shoots flames, throw this wool blanket over it to snuff out the fire" she looked at me with terro rin her eyes.... then I told her to get in and crank the engine :-)
  Aren't wives fun? ;-)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #6 on: October 18, 2004, 09:13:51 pm »
Now that's funny!
Thanks for bringing a little humor into what has otherwise been a mundane Monday....
exibar
« Reply #7 on: October 18, 2004, 10:16:24 pm »
true story too :-)
  She was much much happier INSIDE the truck while I got the timing right.  And there was flames let me tell you, the first time she cranked she gave it the gas and POOF the engine stalls and shoots a flame burst up.  I don't know what went higher the flames or her butt when she jumped ;-)
  Once I turned the distributer quite a bit, no more flames.  But she told me to get one of my friends to help me next time hehehe ;-)
 Mike B
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #8 on: October 19, 2004, 08:27:15 am »
I have tried every de-soldering method over the years and have an expensive Pace de-solder station with vacuum pump etc. But the best method (better than the Pace in most cases) is one of these plunger devices:
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F009%5F007%5F004&product%5Fid=64%2D2098
There is a knack to it though, rather than jabbing the tip onto the joint you need to push the tip onto the melted joint for about a second while still holding the iron on. Otherwise the tip causes heat-soak which prevents the solder from flowing. Yes the tip gets a bit ragged after a while but this does not affect its performance.
JoeB
  • NES Fanatic
« Reply #9 on: October 19, 2004, 11:16:38 am »
Andy.. that's why I use..
when I remove old ROM chips, and solder EPROMs in place, I:
- snip the ROM chip
- heat the feet from the solder side with the iron
- use the pump on the other side to such the foot/solder
- move to next foot
I can do a 32 pin ROM in less than a minute now.   ;D
Mind you I got a huge solder sucker.. one of those that I just flip over and push down on the table (rather than a small thumb one).
