Author Topic: It's possible to use ArcadeVGA as a normal Radeon 9200 under XP ?  (Read 2264 times)
tisurame
  • Last login:August 03, 2025, 10:50:53 am
Well, I would like to buy ArcadeVGA, but first I need to know if it's possible to use it as a normal Radeon 9200 (that output 31khz, instead of 15khz) under Windows XP. I'm asking this because I want to use two different Windows XP installations: one to play only emulators on a Arcade Monitor, and the other to play normal PC Games in high resolution using a PC Monitor. So, if I install normal Catalyst drivers under Windows XP, can I make ArcadeVGA output 31khz ?
Thanks.
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
Re:It's possible to use ArcadeVGA as a normal Radeon 9200 under XP ?
« Reply #1 on: October 10, 2004, 09:00:41 pm »
the arcadeVGA does not support normal pc monitors.
im assuming the bios are flashed and exclude 31khz profiles as such to prevent an accidental hi res siganl from hitting your arcade monitor.
« Last Edit: October 10, 2004, 09:02:14 pm by DYNAGOD »
Enjoying the fruits of technological obsolescence one game at a time...
tisurame
« Reply #2 on: October 10, 2004, 09:38:37 pm »
I think this is true for the bios part and DOS, but what about Windows ? At the first time you plug in the ArcadeVGA on your PC, before you install the windows drivers, don't you get 31khz inside windows ?
seibu
  • Last login:March 28, 2007, 12:55:34 pm
« Reply #3 on: October 11, 2004, 07:01:54 am »
Nope.
Although there is of course the D9200 patch which will get you 31khz in Windows.
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #4 on: October 12, 2004, 12:04:13 am »
I can verify that it does put out 31Khz in windows xp with the d9200 patch.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #5 on: October 12, 2004, 09:57:15 am »
i thought the top VGA connector on the card could be connected to regular SVGA monitor.
seibu
« Reply #6 on: October 12, 2004, 11:22:29 am »
Depends.
It duplicates the middle connector exactly in DOS, Linux, or before the Windows drivers are loaded, so you can run two 15khz monitors. I've tried it and it works really well - I have a separate "viewing gallery" screen for my cocktail now! Great for 4 player games or if you have a lot of people over.
Within windows, I *think* you can configure the second connector to 31Khz, but I can no longer find that info on the Ultimarc site.
