Author Topic: Need some T-molding help  (Read 2893 times)
phantompower
  • Last login:June 14, 2024, 01:20:45 pm
  • The Game is NOT Over!!
    • MameStation
« on: September 11, 2002, 09:28:49 pm »
Hey all.
I have a bit of an issue that needs your help.  I have made a slip-up with the router on one of my two sides.  I fell off the center path that my router bit was travelling and I made an off cut.  To correct it of course, knowing it needed to be centered, I also went over the same piece with the router correctly centered (thinking somehow I could fill in the gaps or glue the T-molding in place).
Well I am here with a question.  How in the heck can I mount that T-molding in a section of the side where the slot is two times as big as it needs to be.
Any help would be much appreciated.
Thanks in advance,
Chuck
SNAAAKE
  • -Banned-
Re:Need some T-molding help
« Reply #1 on: September 11, 2002, 09:32:08 pm »
you mean 2 times deep or wide?
if its deep then powerfull glue..crezy glue..otherwise no idea.
i dont even have t-molding on my stick or cab so no practical experience. :-\
« Last Edit: April 17, 2003, 11:44:56 pm by SNAAAKE »
phantompower
    • MameStation
« Reply #2 on: September 11, 2002, 09:34:15 pm »
It is two-times as wide.  Not deeper.
Sorry for the confusion.
It might still be super glue.  But any ideas would be helpful.
Chuck
SNAAAKE
  • -Banned-
« Reply #3 on: September 11, 2002, 09:36:32 pm »
PUTTY ! ! !
you are working on your second cab right?
putty should be perfect if i were to guess. :)
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #4 on: September 11, 2002, 10:06:49 pm »
Two times wider? 1/8"?
As hard as i looked, I couldn't find a 1/16" slot cutting bit. The best i could find was a 1/8".
Hot glue! Works perfect. My t-molding looks great. Its tough to apply over curves but if you do a little bit at a time and let it set a bit before moving on it works fine. Even if you're a little wider than 1/8" it'll work great. It holds like iron on MDF and plastic.
If you build a frankenpanel, chances are I don't care for you as a person.
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #5 on: September 11, 2002, 10:08:41 pm »
I had a similar slip up when I did mine. I ended up having a section that was double routed for about 6 or 8 inches. What I did is I filled in a little of the extra space with hot melt glue and then installed the molding.
                               Slug54
OSCAR
    • Oscar Controls
« Reply #6 on: September 11, 2002, 10:11:14 pm »
I can vouch for the hot glue method.  I over cut a T-molding slot once and had to do the same thing.  The hot glue held the T-molding solid.
phantompower
    • MameStation
« Reply #7 on: September 13, 2002, 09:08:28 am »
All,
Thanks for the help.  I can't believe I forgot about the power of hot glue.
Worked like a charm.
Thanks again
Chuck
