Author Topic: Vantage project?  (Read 1571 times)
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
Vantage project?
« on: October 07, 2004, 06:19:33 pm »
Just curious if the Vantage project  is still being worked on?  Haven't heard anything lately.
SirPeale
  • Green Mountain Man
Re:Vantage project?
« Reply #1 on: October 07, 2004, 07:24:29 pm »
Lokki is the one that did the majority of the drivers in the new release.  EndTwist did a couple drivers, and hosted webspace for development.
It's not on hold per se, but other projects have taken priority.  Calls for programmers haven't yielded any help.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re:Vantage project?
« Reply #2 on: October 10, 2004, 06:55:05 pm »
is vantage a good alternative to mame? it looks like it runs well on low spec machines.
are mame roms compatible with vantage?
it is DOS program right? what graphics/sounds cards are supported?
is arcadeVGA required or will good (arcade like) display be generated with regular (low spec) VGA card to regular PC monitor (does it generate scan lines?)
would it be good choice to use on a cocktail project that will just play the classics? or better to go for early release of Mame?
what FE(s) are recommended to be used with vantage? which ones are DOS based?
hmmm.....where did i put that old AMD K6 pc....
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re:Vantage project?
« Reply #3 on: October 29, 2004, 01:05:19 pm »
Yes.
Yes. I think the old Mame 0.36final roms work with Mame, though the recently added games use newer roms. There's a ClrMame dat file out there, so you can rebuild them from your Mame roms.
Any graphics card will do. Any soundcard that you can find a DOS driver for will work (about 90% of all soundcards out there)
ArcadeVGA isn't required, Vantage will output arcade resolutions (so long as your graphics card can handle them- old ATi and Trident Blade cards work best)
It'd be an excellent choice.
ArcadeOS
Did you look behind the couch?
