Author Topic: What resolution to use?  (Read 1552 times)
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« on: October 05, 2004, 08:06:06 pm »
27" TV through an ati radeon 7200
Using Mamewah and Windows XP.
I'm currently at 640*480, but all the skins I want to use are 800*600.
Just wondering what most people set a 27" TV up as I guess :) Through windows 800*600 is absoultely unuseable, and I'm wondering if that's going to go through to mamewah (and emulators)
BYOAC users get 5% off with coupon code byoac5
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
Re:What resolution to use?
« Reply #1 on: October 05, 2004, 08:45:21 pm »
What makes it unusable?  I always ran 800x600 with nvidia card to 25" tv.  I upped the font size though.  Are you using an s-video cable?
Sylentwulf
« Reply #2 on: October 06, 2004, 07:54:13 am »
Yeah, I'm using S-video. What I meant was, using 800*600 in windows is unuseable because I can't read ANYTHING. Tried it a bit in mamewah last night, and it's VERY hard to read any text.
Think I'm going to try re-sizing the layouts to 640*480 Although I'm not sure how hard that's going to be? (If at all possible?)
daywane
  • GRRRR!
« Reply #3 on: October 06, 2004, 08:01:11 am »
did you enlarge your font?
I have 800 x 600 on 2 dif. TV's with large fonts and have no problems
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #4 on: October 06, 2004, 09:25:55 am »
The highest pixel resolution an NTSC TV can display is 640 x 480.  Even though it will display an 800 x 600 desktop it's not actually showing any more pixels in resolution.  That's why it is so hard to read.
It's actually not very hard to resize your layouts.  The way I did it was to resize the image first.  It needs to be 80% of it's original size.  Once you have it resized you can open up your mamewah layout designer and open up your desired layout.  Resize it to 640 x 480 and then pull up your background image and resize your artwork image boxes and gamelist boxes until they fit nicely into your resized background image.
Lilwolf
« Reply #5 on: October 06, 2004, 09:27:23 am »
Something that can help...
Try and find the true resolution of your TV.  Then set windows to that.
Then use HW stretching.
On some devices (specifically LCD's.. but I like it for arcade monitors also) you get better results in that all stretching is done in software instead of the monitor or video card..
But for windows / frontend... Raising the font is a must for most people.
cdbrown
  • Bowowow
« Reply #6 on: October 07, 2004, 02:29:35 am »
NTSC - 646x486 60Hz or just 640x480
PAL - 768x576 50Hz
Sylentwulf
« Reply #7 on: October 07, 2004, 09:51:20 am »
It's a LOT easier to change those layouts than I thought :) Guess I'll stick with 640*480.
Suppose I should upload some of the re-sized layouts to screenshotarchive too huh?
GGKoul
  • Cheesecake Apprentice
« Reply #8 on: October 07, 2004, 10:39:17 am »
I have 640x480 from MAME games with LARGE font on so I can read my desktop.  But when I play Tiger Woods, the screen resizes to 800x600 and all the small print is tougher to read.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #9 on: October 08, 2004, 07:13:09 am »
PAL - 768x576 50Hz
this explains why when i select 800x600 there "missing desktop" at the bottom of the screen and cant see the Start  bar.
i am using PAL video monitor.
