Author Topic: Question about dual display...  (Read 1398 times)
tisurame
  • Last login:August 03, 2025, 10:50:53 am
« on: October 04, 2004, 11:55:20 pm »
I would like to know, if a card with tv-out and dual display option, like Radeon, could work like this...
I want to use the s-video tv-out to display on TV the same picture that`s coming from the VGA output, both at the same time.
Since you can see the BIOS and boot screens using the s-video cable...this s-video picture would work for me to secure that I don't change my TV video mode to RGB, if I still don't get the right frequency.
It could work like this, even using DOS ?
Thanks.
pcates
  • Last login:January 05, 2011, 08:15:57 pm
Re:Question about dual display...
« Reply #1 on: October 06, 2004, 12:57:55 pm »
I have one and you can get it to display on both at the same time. I have not tried it in DOS, but when the computer boots, you can see the boot sequence on the TV, so I assume that it would work in DOS also.
tisurame
« Reply #2 on: October 06, 2004, 04:31:41 pm »
But you can see the boot sequence on TV and on the monitor at the same time or you only can see that when you are inside Windows ?
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #3 on: October 06, 2004, 06:14:25 pm »
The Radeon allows display on both during the entire boot sequence.  I've also got my old GeForce 2 MX do the same (and then moved that to strictly TV use).
tisurame
« Reply #4 on: October 06, 2004, 06:21:10 pm »
I would like to ask another question...
Using programs that directly program the VGA signal, like AdvanceMame, AdvanceCab etc...will make any interference or stop the s-video output ?
Crazy Cooter
« Reply #5 on: October 07, 2004, 04:57:36 pm »
I don't know, I've never used those progs.
