Author Topic: ArcadeVGA rotate windows desktop 180degs  (Read 1976 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: September 28, 2004, 09:56:55 pm »
anyone know of a utility that will allow rotation of the windows desktop by 180degs?
i have my monitor installed "upside down" in my cocktail cab (to allow for install of coin door mech). i have ArcadeVGA with ATI driver that supports rotation in display control panel - but the rotate 180deg setting does not stay set when i reboot windows? and reverts to 0deg rotation and display upside down desktop.
maybe i can set the ATI rotation directly in the registry? maybe that would prevent it being reset on reboot?
any suggestions? (other than simply change orientation of the monitor - it simply wont fit!)
Rocky
Re:ArcadeVGA rotate windows desktop 180degs
« Reply #1 on: September 29, 2004, 02:22:23 pm »
It is possible to switch wires on the monitor neck board to make this happen.
I don't recall the colors now (and you can FRY you monitor if you switch the wrong wires), but there are 2 wires for vertical and 2 for horizontal.  By switching these you can swap orientation.
Do a search in the monitor forum or on KLOV message boards.
Good luck,
Rocky
rchadd
  • Made in Cornwall
« Reply #2 on: September 30, 2004, 07:19:10 pm »
yes i did the yoke mod - it worked perfectly!
Rocky
« Reply #3 on: October 03, 2004, 09:02:17 pm »
That's great.  :D
Glad you were able to do the hardware fix.
