Author Topic: filtering on Adult titles in MamWah  (Read 1843 times)
exibar
  • Last login:January 02, 2025, 11:38:59 pm
  • I'm the creator of Exibar's Lair!
« on: September 26, 2004, 10:39:36 pm »
How would I go about filtering the adult games in MameWah/mame?  I didn't see an option in there in the MameWah filter listing.  Do I just have to place them manually into the filtered game listing?
 thanks!
  Mike B
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
Re:filtering on Adult titles in MamWah
« Reply #1 on: September 27, 2004, 01:42:18 am »
There is also another way to filter these games is to Add a new emulator with a new related games rom path.
                            OR
Minwah will tell you the very best solution.
BLUE BIRDS FLY WITH BLUE BIRDS
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
« Reply #2 on: September 27, 2004, 02:03:23 am »
Are you using catver.ini?   I know it has it as a filter.  I am running Mamewah .97 so I don't know if maybe it doesn't work in the new 1.51 or what...
I haven't upgraded yet- I'm waiting for a new version of  Mr. Butler's Mamewah Setup because I'm incredibly lazy.  ;D
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #3 on: September 27, 2004, 03:13:22 am »
You should use catver.ini from http://www.catver.com/, and that file work fine with 1.51.
The configuration for 1.51 is easier than 0.96, without using the Mamewah setup.
exibar
« Reply #4 on: September 27, 2004, 10:57:25 am »
cool!  I'll give it a try :-)
  thanks!
  Mike B
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #5 on: September 27, 2004, 03:39:55 pm »
similar question:
how would you go through your roms and sort out all of the adult roms into different folders?  I have them filtered in mamewah, now i just need to get them to not show up on HCs emusaver.  :o
I used to know how to do this.  honest.
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
« Reply #6 on: September 27, 2004, 05:43:07 pm »
similar question:
Actual different Windows folders?  Cut & paste.  That's the only option that I know of until someone writes us a rom manager that'll allow us to batch move catagories with a GUI.
I think there may be a DOS batch program that someone wrote floating around out there somewhere though.
If you can't be a good example at least try to be a horrible reminder.
« Reply #7 on: September 27, 2004, 07:43:49 pm »
similar question:
Use saver_type run_random_game_using_wrapper with HC's EmuSaver and you don't need to move the roms, it will only pick games from the current list ;)
Luxury
    • arcadeZERO
« Reply #8 on: September 28, 2004, 12:14:49 pm »
Thanks.  I'll try it tonight  :)
gap
  • Last login:November 02, 2004, 09:06:12 pm
  • Howdy!
    • MAMEGAP
« Reply #9 on: September 29, 2004, 08:04:07 am »
similar question:
I used Mame Content Manager (MCM) to remove all the adult roms.  Alternately, it can rename them rather than delete them.
