Author Topic: Multiple Playstation USB adaptors??  (Read 2845 times)
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« on: September 08, 2002, 12:47:28 pm »
I read somewhere that certain PSX to USB gamepad adaptors will only work when connected to the PC and not through a hub.  Does anybody know if this is true and what other limitations these adaptors may have?  Like how many can you use on a PC? thanks!
« Last Edit: September 08, 2002, 12:48:22 pm by brandon »
The Man
  • Last login:August 27, 2009, 03:41:49 pm
  • I'm easy like Sunday mornin!
Re:Multiple Playstation USB adaptors??
« Reply #1 on: September 08, 2002, 12:57:39 pm »
Well I've got two of them, but i'm using it with N64 controlers.  Well once controler really.  I can't get the second to work correctly.  I've sent a unit back and then gave me another one, but it still has the same problem.  They told be to try another N64 joypad, but thats not the problem becuase I can't get this adaptor to work on any pc correctly.  Must be something with a chip change or something.
So, to answer your question. I don't have any PS controllers and it doesn't seem to work with two N64 controllers.
Good Luck!
TM
SNAAAKE
  • -Banned-
« Reply #2 on: September 08, 2002, 02:04:58 pm »
i work perfectly under any os.. 98,xp,me and so...
i used to have 4 of them..now i only got 2..works great...
i think you can use a hub because the hub as nothin to do with the usb converters..it will only give you more ports to connect more usb stuff. good luck  ;)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: September 08, 2002, 10:10:49 pm »
http://forums.ddrmaniax.net/index.php?act=ST&f=6&t=1335&hl=usb&s=1054af21d9363d5fe94e7c1e298c5979
When they say the adaptor doesn;t work on that site they mean it doesn't register up and down or left and right at the same time.
There is a dual psx to usb adaptor there.
I think it'd need power only for force feedback controllers.
There are powered USB hubs out there.
« Last Edit: September 08, 2002, 10:11:20 pm by SirPoonga »
brandon
« Reply #4 on: September 09, 2002, 10:40:51 am »
thanks guys,  I think it was just the Kiki-joy model that had the problem.  Most ever site I have seen says they are limited to 2 and cant be used with a hub.  Oh well, I bought one at Radio Shack the other day and it works like a charm!  Here's a link to the crapy kiki-joy if anybody wants to check it out.
http://jandaman.cybrhost.com/Merchant2/merchant.mv?Session_ID=3D7B61C0000632AE00007CE100000000&Screen=PROD&Store_Code=JIVGA&Product_Code=psxkikijoy&Category_Code=PC
