Author Topic: zsnes on mamewah  (Read 1912 times)
Johnson
  • Last login:December 07, 2004, 05:42:44 am
zsnes on mamewah
« on: September 23, 2004, 09:20:32 pm »
Hi guys
I know this has been covered off here and there but I can't get mamewah to load up any zsnes roms. when i go to add a game or generate a list it just comes up blank. I've amended the ini files etc... but still no go, any ideas? Thanks
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
Re:zsnes on mamewah
« Reply #1 on: September 23, 2004, 10:58:01 pm »
http://www.screenshotarchive.com/mwhelp.htm
Make sure your settings match that, and you are using the hacked version of the emulator.  Hope that helps.
first off your and idiot
Re:zsnes on mamewah
« Reply #2 on: September 24, 2004, 06:29:52 am »
Edit your \mamewah\ini\zsnes.ini file, and make sure it says:
current_list                              0
...at the bottom.  I think the file I included originally may have set this to 1 (did it say 'Generate Filtered List...'??  You should now get 'Generate List' under Games List Options.
Johnson
Re:zsnes on mamewah
« Reply #3 on: September 25, 2004, 08:31:04 pm »
Worked a treat , Thanks Minwah!!!!!!!!!!
